Simple Waterproof Containers
1,070
14
14
Published
Introduction: Simple Waterproof Containers
About: I'm a student who loves making of all kinds. It could be building a diy windmill, cooking, photography, you name it and if I don't already know it I'd love to learn how. I am committed to making informative,...
In this Instructable you are going to learn how to make a simple waterproof and air tight container. Due to the size of the finished containers they are perfect for keeping in a first aid kit or survival kit and can be filled with a various items like small single uses of Neosporin or anti-itch cream, iodine or other chemical tablets for water purification, matches or anything else you can jam inside a straw. As and added bonus depending on what you put in them they even float! So without further ado lets get on to the making.
**Please consider voting for this project in the contests I've entered**
Step 1: Materials:
To make these versatile little containers your going to need a few things.
The bill of material is as follows:
Plastic drinking straws - The most important part, they can be any size as long as they are the plastic variety and not the paper ones.
Neosporin or other item - For this example I'll be using Neosporin as the item I'd like to stay dry but you could really use anything that will fit in the straw. Some other suitable candidates could be various other ointments and creams, salt and pepper, cotton for starting fires and if you are careful you can put a few matches in one.
Matches or a lighter - Used for sealing the straws. I had matches but a lighter would be more convenient as it can be lit with one hand.
Pliers and scissors - holding and cutting respectively.
Step 2: Cut and Seal:
Choose a length for your straws that will fit the item you are trying to put inside plus a 1/4 inch or so. Mine are fairly small so that they hold single use amounts of Neosporin but you could use the whole straw if your item is that big.
Once you have a good amount of straws cut to length you're ready to seal them. Take one straw and put it in the pliers so there is around an 1/8 inch of the straw sticking out on one side (Fig.2). Take your match or lighter light it and then hold it to the straw to melt It (Fig.3). Before the plastic cools turn your pliers and squish the plastic against your work surface to make an air and water tight seal.
Step 3: Fill:
Now it's time to fill the containers. I just took the Neosporin lined it up and squeezed in enough to fill up the straw. I then used the end of a match to push the Neosporin down into the straw to make about 1/4 inch of room at the top. When putting matches in I like to drop them in with the head at the already sealed end just to keep them as far away as possible from the heat while sealing the end.
Step 4: Final Seal:
To seal up the straw we just have to repeat what was did before. Take your pliers squeeze the straw so there's roughly an 1/8 inch on one side. Take your matches or lighter and melt the end, squishing it against the work surface like before to make a nice seal.
You're waterproof straw container is now complete. When its time to use them just cut of an end and squeeze or dump out the contents knowing that they will be perfectly dry. I keep a few of these in my first aid kit so I know I will always have dry matches, tinder, and things such as ibuprofen and Tylenol.
MacGyver Challenge
Runner Up in the
MacGyver Challenge
    • Game Life Contest
      Game Life Contest
    • Creative Misuse Contest
    • Oil Contest
      Oil Contest
    14 Discussions
    is there any way to seal it without using matches or fire? Like some electrical tape? I go camping all the time with my scout troop and we go backpacking soon and I thought this would be a great idea but I don't have access to fire. However I do have a lot of tape on hand. Could you help a fellow crafter?
    If you have access to a hot plate or other heat source just heat the pliers.
    A word of caution, however: Heating metal tends to affect the structure of the metal, so I only use an old pair of pliers for this.
    I can’t see any reason why electronically tape couldn’t be used. I would say use a small piece then pinch the end and put the small piece over. Then once that small piece is on wrap the whole thing in electrical tape to make sure your small piece doesn’t come off.
    sounds like a good idea. Thanks man. How about duct tape? Will that work? I think it would just like electric tape, but I would have to cut off an excess, would I?
    Fantastic idea! I usually pack my son's medicine similar to this. I measure it out in a plastic pipette and seal it with lighter and pliers. But I never thought to do it with straws. Brilliant!
    In my experience with pipettes, an open flame can get a bit too hot. I have accidentally melted off the entire tip of the pipett a few times. A nice solution to this is to just heat the pliers. When I'm sealing up a bunch I just put the tip of the pliers on a hot plate between each use. That way no flame is necessary.
    Ahh great idea, then you don't have to try to light the match with one hand.
    Right, so now you have both hands to work with.
    I am going to do it, I have a trailer for my summer camping, but we get monsoon rains and stuff gets damp.
    Love this so very smart so many uses with different size straws .....thanks for posting a GREAT instructional post. A great project for older backpacking Scouts!
