Simple "Wet the Bed" Prank
Introduction: Simple "Wet the Bed" Prank
Simple prank to make it look like someone "wet the bed" All you need is:
>Ziplock bag (cannot use zipper  ziplock)
>VICTIM's bed
Step 1: Construct the Prank
Take the Ziplock and fill it with water. If you use a double seal bag then cut off the first seal.
Step 2: Close It All Up
seal the bag but leave a very small gap between the seal. if you leave i open too much it will leak and give away the prank. if you seal it too much it won't burst open. it is okay if it leaks a little. if you don't want to risk it you can try using one strip of scotch tape to temporarily seal it.
Step 3: Placing
Now place it dirrectly under the pillowcase. wait until morning........ your victim
should have a nice and wet bed! Have fun :)
    • Trash to Treasure
      Trash to Treasure
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    Hubby's Air force buddies tried it on him. It didn't work; doesn't work on everybody.
    Does putting their hand in warm water actually make them wet the bed?
    the mythbusters tested it and it doesn't
    A friend of mine did it an it worked.
    wow then i have to try that thanx, i guess the mythbusters aren't right about everything :(
    I'm just to chicken to try myself.
    you really should try it for yourself and post the results on this instructable
    i understand, mainly because i dont think i will ever do this
