Simple Amplifier With TDA2822M
Introduction: Simple Amplifier With TDA2822M
In this instructable you'll learn, how to make a simple audio amplifier with the TDA2822M. The total cost of the components shouldn't cost much (5$ max) and because the circuit is very simple you don't need a PCB, you can make it on a protoboard.
Step 1: Things You'll Need
You'll need a soldering iron, cutters and solder.
From the components you'll need:
  • TDA2822M 1pcs
  • 10k resistor 1pcs
  • 4k7 resistor 2pcs
  • 10nF cap 1pcs
  • 0u1F cap 2pcs
  • 10uF cap 2pcs
  • "bornier" connector 3pcs
Step 2: Assembly
Start by putting a resistors into the board. When you put them in, bend legs for a little, so they'll stay in. Than solder it .Than put the IC in and solder it. That put the capacitors in and solder than. And finally solder the bornier connectors in.
Step 3: Finish
Congrats now you have your mini amplifier. On the left you have power input. I recommend using 3-4V so there won't be much heat dissipation. In the middle there is a speaker output and on the right there is input.
*Note* It isn't my design of a PCB or a circuit
    • Science of Cooking
      Science of Cooking
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
    Hello, will this also work for the TDA2822D instead?
    Hello, the D stands just for a version in SO8 housing instead of DIP8 as I have used. The functionality is the same, so you can use it :)
    Little amps like this are great! Could you add a clear picture of the schematic?
    oh thanks for reminding me I forgot to upload the file. Will do it ASAP as I get back my internet connection on a computer
