Simple and Cheap Thermocouple Using Thermistor
398
6
Posted
Introduction: Simple and Cheap Thermocouple Using Thermistor
simple and cheap temperature sensor using NTC thermistor
thermistor changes its resistance with change in time using this property we are building temperature sensor to know more about thermistor
https://en.wikipedia.org/wiki/Thermistor
Step 1: Components Required
Arduino uno (or) any arduino will work
some jumper wires and bread board
1 X 10 k resistor
1X NTC 10k thermistor
Step 2: Connections
(Ground) ---- (10k-Resistor) -------|------- (Thermistor) ---- (+5v)
| Analog Pin 0
Step 3: Code for Fahrenheit
#include
double Thermistor(int RawADC) { double Temp; Temp = log(10000.0*((1024.0/RawADC-1))); // =log(10000.0/(1024.0/RawADC-1)) // for pull-up configuration Temp = 1 / (0.001129148 + (0.000234125 + (0.0000000876741 * Temp * Temp ))* Temp ); Temp = Temp - 273.15; // Convert Kelvin to Celcius Temp = (Temp * 9.0)/ 5.0 +32; // Convert Celcius to Fahrenheit return Temp; }
void setup() { Serial.begin(115200); }
void loop() { Serial.println(int(Thermistor(analogRead(0)))); // display Fahrenheit delay(1000); }
Step 4: Code for Celsius
#include
double Thermistor(int RawADC) { double Temp; Temp = log(10000.0*((1024.0/RawADC-1))); // =log(10000.0/(1024.0/RawADC-1)) // for pull-up configuration Temp = 1 / (0.001129148 + (0.000234125 + (0.0000000876741 * Temp * Temp ))* Temp ); Temp = Temp - 273.15; // Convert Kelvin to Celcius return Temp; }
Step 5: Conclusion
after completing all the steps now open the serial monitor and set the baud to 115200 you can see the temperature readings
Further developments you can add lcd to this
thank you :)
if you have any doubts feel free to ask
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Microcontroller Contest
    You might like to consider changing the title as there is such a component as a thermocouple and it works on a totally different way to a thermistor. But it's a good example of how to use a sensor with the Arduino.
