Simple and Low Cost 6 Legs Spider Lego Robot
4,068
25
5
Published
Introduction: Simple and Low Cost 6 Legs Spider Lego Robot
Sorry for kind of rush for this document.
This is a simple 6 legs, 12 mini servo spider and make used of Lego plate, you can add more lego on your final design. The cost is just 12 mini servos + 3d printed Lego mount + your Lego
Step 1: Prepare 6 Sets of Mini Servo Lego Mount
You need 12 mini servo MG90S and 6 set of this Mini servo Lego adapter, the green one for mount on the lego plate. It has 3 faces, can use any of it for difference orientation.
And a lego plate, what I am using is a 4" x 8" lego plate.
Step 2: Plug in Mini Servo.
plug in mini servo and screw it tide.
Step 3:
For another mount, there is a gap at the bottom which suitable for one mini servo header.
Then put in a long screw on the top ( this screw should come with the servo motor )
Then screw it on the mini servo which plugged on the base mount.
Step 4: Put on Spider Leg
For the spider legs, put another single arm mini servo header on one side, then mount on the mini servo motor.
Step 5: Plug on Lego Plate
Final step is plug on Lego plate. I still have 2 spider legs not printed. So it only show you 4 legs here. I will keep it update.
Thanks for viewing.
    • Oil Contest
      Oil Contest
    • Stick It! Contest
      Stick It! Contest
    • Pets Challenge
      Pets Challenge
    5 Comments
    excited to try this, crazy about Lego adapters. Will you include the 3D print file?
    for those who do not ow a 3d printer, here is the the pre-printed
    http://www.ebay.com/itm/2-set-4-pc-Lego-Mini-servo-Mount-SG90-easy-flexible-robot-design-connection-/262197090100?hash=item3d0c2a1734:g:HQUAAOSwSdZWcx3l
    fantastic, thank you much!
    Awesome robot. I love how it is Lego based so you can build your own housing anyway that you want.
