loading
The Raspberry Pi is an amazing 35 dollars mini-computer. It allows you to do everything you could do with a regular Linux computer (Connecting to the internet, watching videos, launching applications, ...) but also to interact with the world surrounding it, just like an Arduino. That's why I qualify it as a mix between a computer and a micro-controller.
That's also why I chose it for this project. I'm going to show you how to control LEDs with your Raspberry Pi. Firstly directly from the Raspberry Pi itself, then from any device in your house like your Smartphone or your tablet.
Here is a very good example of what you can achieve after reading this Instructable: https://www.instructables.com/id/Web-Controlled-8-Channel-Powerstrip/. Thanks to Rleddington for his amazing project.
Update: French version here
Step 1: The electronic part
     The electronic part is nothing special, it's only 8 LEDs with their protecting resistor. The only hard part is to connect the LEDs to the good pin on the Raspberry Pi. Indeed, I'll be using later a library called Wiring Pi made by Gordon Henderson (You can visit his website at: http://wiringpi.com/) and the pin's numbers used in this library aren't the same than the ones on the Raspberry Pi. See this page for matches: http://wiringpi.com/pins/ (just be careful about your Raspberry Pi revision, the pinout isn't exactly the same). I'll be using Wiring pins 0 to 7.
     Concerning the resistors, they should be 270Ω but since I don't have this precise value, I'm using 560Ω resistors (LEDs are just less bright).
     Finally, I've made two schematics to make it simpler. The first one (with the complete Raspberry Pi) is showing you the real pins as they are shown on the board. The second one is a simplified version, it's showing you only the useful pins and their matches in the Wiring Pi library (GPIO Wiring number/Actual number on the board).
Step 2: Installing and using the Wiring Pi library
As said before, Wiring Pi is a library. It simplifies a lot using the Raspberry Pi GPIOs (one command instead a long process). It also means that you can use it in any of your C codes. However, we won't build and use a C program but the Gpio utility. It's a software made by Gordon and coming with the library. It allows you to control the GPIOs in a bash script or directly in a command line. Using this utility is however a lot slower than a C program.
We first need to install it. Gordon himself is explaining it very well on his website: http://wiringpi.com/download-and-install/. You just need to download it from GIT then to build it using the ./build command.
You should now be able to use the Gpio utility, type the "gpio mode 0 out" command to test it out. If nothing special appears, everything's fine. Else, if the board is printing "command not found error" or something like that, be sure that you've followed the guide and build the library.
Let's turn on and off the first LED (Wiring pin 0). You first need to set the pin as an output. Use the "gpio mode 0 out" command to do so. "0" is the wiring pin number and "out" simply stands for output. Now, use the "gpio write 0 1" command to turn on your LED. "0" is again the pin number and "1" is the status (1 for ON and 0 for OFF). If everything's fine you should see your LED shining. To turn it off, simply use the "gpio write 0 0" command.
Just a little tip, if you want to use the actual pin number (GPIO-17) instead of the Wiring Pi number (0 is corresponding to GPIO-17), use the -g flag in your command. Ex: "gpio -g write 17 1" instead of "gpio write 0 1".
There is also the "gpio read" command which allows you to read the pin's status. It may seems useless when the pin has been set as an output but it allows you to be sure of the pin's status when you can't see the LED. Using it is as simple as before, just type "gpio read 0" where "0" is the wiring pin number. The command is returning the pin's status (again 1 for ON and 0 for OFF).
Finally the Wiring Pi library is containing a lot of other commands/functions but I'm not gonna cover them in this instructable since there are not useful here. See this page if you are more curious: http://wiringpi.com/reference/ (library's functions) and https://projects.drogon.net/raspberry-pi/wiringpi/the-gpio-utility/ or the "man gpio" command for the Gpio utility.
Now that you can use this utility, let's play a little bit with it. You can first, if it's not already the case, control remotely your Raspberry Pi with SSH. You can use Putty for Windows or ServerAuditor for your Smartphone. Then have fun with bash scripts such as this one which is turning on LEDs 0 to 7, waiting 2 seconds, then turning them off again:
#!/bin/bash
#set mode to output
for i in 0 1 2 3 4 5 6 7;
do gpio mode $i out;
done;
#turn on LEDs 0 to 7
do gpio write $i 1;
done;
#wait 2 seconds
sleep 2;
#turn LEDs off
do gpio write $i 0;
done;
Step 3: Installing a web server then transferring your website to it
Controlling the LEDs remotely with SSH is pretty cool but the interface (console) isn't very user friendly and typing the commands every time is long and annoying. That's why we need a graphical interface for our project.
Programming an app for each OS (IOS, Android, Windows phone, Mac, Linux, Windows,...) would be too long and would require to know a lot of different languages for nearly nothing. It would also require to do an application running on the Raspberry Pi. Making it this way would be overkill and time wasting.
That's why a website is the best solution, it's compatible with all devices and you "only" need to know four languages: HTML (for the page's skeleton), CSS (page's style), PHP (interactions with the server) and JavaScript (interactions with the user).
We indeed need to install a web server on the Raspberry Pi. In our case, we don't need a MySQL database, only a HTTP server and its PHP extension.
After updating your Raspberry Pi with the "sudo apt-get update" command, type "sudo apt-get install apache2 php5 libapache2-mod-php5" to install Apache HTTP server and PHP5 extension. You can now test if your server is working by typing the IP of your Raspberry Pi in your browser. You should now see a "It works!" page with two other lines. If you don't, then check your board's IP, try re-installing Apache or rebooting your Raspberry Pi. This page is showing that your Apache server is working properly but not its PHP extension. To check it, navigate to your "/var/www/" directory by using the "cd /var/www/" command. If you use the "ls" command, you should have only one file named "index.html". This file corresponds to the "It works!" page. You can now delete it ("sudo rm index.html") and create another one called "index.php" (use "sudo nano index.php"). Then type the following text:
<?php
    phpinfo();
After saving it using ^o (Ctrl + o), exit nano editor with ^x (Ctrl + x). Now if you refresh your browser, you should see a long page with lots of information about your server and PHP. If you don't, check the index.php file, try re-installing PHP or try to understand the error displayed instead of the page (Google it if necessary).
If both pages were correctly displayed, then you now have a fully functional Apache/PHP server but using nano every time is annoying and not very comfortable. We indeed need to transfer files from your computer to your Raspberry Pi. You may want to install a FTP server but it isn't necessary, you can already transfer files using the SFTP protocol. All you need is an SFTP client on your computer. I'm personally using WinSCP for Windows but there are Cyberduck for mac and Filezilla for Linux. If you try transferring files before reading what's next, you'll probably have issues such as "access refused" or "cannot write here". It's due to the fact that the user pi isn't owning the www directory. Indeed, if you try the "ls -l /var/www" command, you'll see that only root (the super user) is owning the www directory. You can (like I did) use the "sudo chown -R pi /var/www" command to change it or create a group named www-data in which you place the pi user then use the "sudo chown -R www-data /var/www" command. The -R flag is standing for recursive, it means that the user/group isn't owning only the directory itself but also everything inside (index.php as example).
You now have your server ready to work and to receive web pages. Have fun with it if know HTML, CSS and PHP.
Edit:Apparently, apache's default folder has been changed to "var/www/html" so may need to adapt the previous commands.
Step 4: Controlling the LEDs with PHP
We now have a web server and a library, let' put them together.
PHP stands for "PHP: Hypertext Preprocessor", It's a server side scripting language. It means that the PHP code is executed once (each time the page is requested) by the server and cannot be seen by the client. I used this language because it's the most popular (and that's the only one I know) but you have to know that they are other server side languages like Python, Ruby, Lua, Perl, ... However, I don't know if the functions we are gonna use have their equivalents in these languages.
Executing applications with a PHP code can be done with two different functions: exec (for execute) and system. Firstly, the "system" function. It takes two parameters: "system ( string $command, int $return_var )", as you guessed it, the first parameter is the command to execute and the second one is the returned status of the executed command. The second parameter isn't compulsory. You can use this function if you don't expect an answer from the command executed. Thus, you can use it if you need to execute "gpio mode 0 out" or "gpio write 0 1" commands. Example:
<?php
     system ( "gpio mode 0 out" );
     system ( "gpio write 0 1" );
Then, the "exec" function. This function is making exactly the same work than "system" but it reads and stores what the command printed. It takes three parameters: "exec ( string $command, array $output, int $return_var )", again $command and $return_var are the same parameters and the only difference is the $output array. As it's name says it will store the command's output in an array. Thus, you can use this function if you need what the command prints like with the "gpio read 0" command. Example:
<?php
     exec ( "gpio read 0", $status );
     print_r ( $status );
You can now execute nearly whatever command you want but let's make a little PHP example to practice: We will turn on LEDs 0 to 7, then wait 2 seconds, then turn them off. Just like we did with the bash script. Edit the index.php file with the following code:
<?php
$status = array ( 0 );
//set pins mode to output
for ($i = 0; $i <= 7; $i++ ) {
     system ( "gpio mode ".$i." out" );
//turns on the LEDs
     system ( "gpio write ".$i." 1" );
//reads and prints the LEDs status
     exec ( "gpio read ".$i, $status );
     echo ( $status[0] );
//waits 2 seconds
sleep ( 2 );
//turns off the LEDs
     system ( "gpio write ".$i." 0" );
Step 5: Making the interface
We can now control our Raspberry Pi with simple PHP scripts but there is no interaction with the user and thereby we can't choose the LED to turn on/off. Let's make the interface!
It's composed of pictures I've found on Google images (search for "on/off button"). One was green and the other one red, I just added the number using The Gimp. Each picture/button is corresponding to its LED, so if you click on one of these, the corresponding LED will be turned on/off and the picture will be changed to its green/red version. The page's skeleton will be made with HTML, the server interactions and page's generation with PHP and at last JavaScript to manage interactions with the user and page's animation. If you don't know, JavaScript is a client side language and unlike PHP, it's executed not once, but continuously by your browser. That's why you can change the page's look without reloading it or accessing to an other. If you are wondering why I spoke about CSS before, it's just because we need it for some style and page-layout like the the black background. I didn't make a full .css file because it wasn't necessary here.
We first need an "index.php" file (extension is .php and not .html cause we will use PHP code, it helps the server to know if there is PHP to execute before sending the generated page). This page is the main page containing the 8 buttons. These buttons are first generated with a "exec ( "gpio read ".$i, $output );" in a for loop. Then we need to detect when the user is clicking on one of these buttons. That's where the JavaScript is useful, I put it in a separate file called "script.js" but it's still included in index.php. The script is simply adding an event listener to all of the eight buttons and each time one of these is pressed, it uses a function which is asking for gpio.php, receiving the answer then returning it. Finally, in function of this, the JavaScript changes the button to red (for OFF) or to green (for ON). Now, the last page: gpio.php. It contains the PHP code to turn on/off the LEDs in function of what the JavaScript function sent. The user shouldn't normally ask for this precise page but there is one golden rule when creating websites and you should always remember this one: "NEVER TRUST THE USER". In other words, never think the user is always gonna do what you think he's gonna do. Thus, I added some securities at the begin of the PHP code like making sure the user gave a correct value and not a letter as example. I made a small diagram to sum up all this text.
You can download the full project directly on this website below.
Step 6: Conclusion and ideas of improvements
This small but long explained project was fun and I learned a lot. I hope you did the same. However, controlling LEDs isn't very useful. That's why what we made is rather a tool than a real project. Christmas is soon (about one and a half months from the day I wrote this instructable) so why not replacing LEDs by relays and controlling lights around your house. There are some pretty good relay boards for the Raspberry Pi on Ebay and more generally on the Internet. Alternatively, and if you're not scared about working on your house, you can even control your house's lights, garage door, coffee machine, heating system, ... The only limit is your imagination.
There are also a lot of possible improvements like changing the interface, adding more LEDs via a shift register, using vocal recognition, ... In addition, with PHP, you are not limited to gpio write or read. You can use the full Gpio utility and thus interact with other devices with UART or any other implemented protocol. You can also use PWM (Pulse Width Modification) to control servos, ...
Writing this Instructable and sharing my little knowledge was a great pleasure for me and I hope it was the same for you to read it. I tried to keep it simple but at the same time to teach the most possible. I didn't want to do a simple and dumb step by step: "download this code, run it, you're done". I think that something is useless to learn until you understand how it works or why you do this and not that. Let me know if you think it's the good way or if I should do it otherwise.
PS: This is my very first instructable and English is not my native language so if you have any comment, advice, suggestion, idea, ... Just let me know, I'll be glad to answer you and of course to learn.
fantastic tut thank you very much.
<p>hi can you share the code sir..</p>
<p>hi. i have a question . how to make reverse coding in index.php to use on relay board ?</p>
<p>Thanks! Gave me a good baseline to begin my project!</p>
Wonderfully explained! Hats off to you creator!
<p>Hello,</p><p>thanks for the nice instructable! It works great!</p>
<p>Hello, I love this article! But I am having problems...</p><p>I am using Flask as my web server and created php web pages. </p><p>Right now I am just trying to get the bare simples to work. I cannot get the &quot;system&quot; or &quot;exec&quot; commands to work or do anything. Any suggestions?</p>
<p>Great stuff.........Tx for sharing friend...</p>
<p>Thank you for the excellent instructable; this is exactly what I was looking for when I wanted to control my 8 channel relay board over the web with a GUI. As others, I wanted to use different gpio pins than 0-7 that TheFreeElectron used and he actually mentioned how to do it in the comments, but I thought I would post the slightly modified gpio.php and index.php files for others that had trouble specifying what gpio pins to trigger. Like TheFreeElectron said, add an array named $pin in the gpio.php file with your specific pin numbers - will look something like this depending on the pins you are using: &quot;$pin = array(21,22,23,24,25,27,28,29);&quot;. Then change the &quot;$pic&quot; to &quot;$pin[$pic]&quot; in the &quot;system&quot; and &quot;exec&quot; lines of the code. Next, in the index.php file, add the same &quot;$pin = array(21,22,23,24,25,27,28,29);&quot; array then change the &quot;$i&quot; to &quot;$pin[$i]&quot; in the &quot;system&quot; and &quot;exec&quot; lines of code. That's all you you have to do to be able to specify what pins you want to control with this slick web app. Thanks again, TheFreeElectron!</p>
<p>Thank you for the great instructable. It provided me with a base for my automation project.Best Regards,</p>
<p>how can i run python script on web page. i want to auto increment a variable in python script and display the variable on webpage</p>
<p>Hi, great instructable and awesome project! I do however have some issues. I have connected to relays to my pi, on gpio &quot;0&quot; and &quot;2&quot;. Therefore I have also added an array to my gpio.php file, and fetching the values in the array using $i. In index.php I have exchanged the &quot;default&quot; for loop with a for loop which produces numbers from 0 to 2. And inside I have an if-statement with a &quot;$i % 2 == 0&quot; statement.</p><p>The thing is, when I do &quot;/gpio.php?pic=x&quot; with &quot;0&quot; and &quot;1&quot; as values for x - it works fine! The relays turn of and on nicely. But when I press the two buttons showing up, it only works for button &quot;0&quot; - not for button &quot;2&quot;.</p><p>I have been at it for severaly hours over 2 evenings, and I am tired... Are anyone able to spot the problem from what I just wrote?</p><p>Thanks!</p>
<p>Cool project! not too complicated and you can do a lot with it.</p>
<p>Hello, thanks for your tutorial. (:</p><p>I have a question about the tutorial. On my raspberry pi 3 I have installed wiring pi, apache2 webserver and php5. </p><p>How can you use wiringpi on the webserver? i can't find anything about wiringpi in your index.php , gpio.php , script.js? </p><p>Best regards,</p><p>Rasmus.</p>
<p>If you refer to the gpio.php file, there is a section to read and a section to write the output of the gpio. The php code executes a system command that is similar to typing it from the command line.</p>
<p>This was a fun project to build and i have used it for several projects. However I was wondering if it is possible to make the output momentary as apposed to the toggle setup. If so could someone provide me with more info as how to do this, it would be greatly appreciated. I hope to be able to use this in a remote controlled car.</p>
<p>Really well done instructable. Thanks for writing it. It was fun to build. For other builders, I put the .php, .js files and that data folder in the /var/www/html<br>folder on the RPi using WINSCP after having run the sudo chown -R pi /var/www. I just started with one LED to test. </p>
<p>can you give me a video tutorial of this whole project? please it will a big help</p>
<p>Excellent instructable. I had a lot of fun making this and I am definitely gonna do more like these!</p>
<p>Can you give me a video tutorial of this whole project .. please??</p>
<p>i cant get this code running '<em>sudo chown -R pi /var/www/html' , can someone help me with it</em></p><p><em> <br></em></p>
<p>Awesome, this is my first project with my RaspPi, and I feel it really helped me to learn and to see what is it able to do. Thank you very much for such a great work!</p>
<p>Hi, a great project, I got it working first time. However the pins I want to you are different.</p><p>I want to change to GPIO pins 17,27,22,5,6,13 but I cannot see how to change the pins in your scrips.</p><p>Any help would be very welcome.</p>
<p>I was really hoping he'd answer this. It was also asked before and it was stated that it is already in the instructions how to. Really though, all that is in the instructions was how to wire your GPIO to pins 0 -7, not how to re-wire your existing project to those pins... </p><p>I think question could be better asked is how to alter from pins 0-7 so those of us not starting from scratch can use the pins already in use. </p>
Hi!<br><br>I think I already answered this question in another comment but if I didn't then here's how you can use whatever pins you want:<br>-Use the same code<br>-In gpio.php add an array making the link between numbers 0 to 7 and the pins' number you want to use. For instance [5,6,7,8...,13] if you want to use pins 5 to 13. It doesn't need to be in a particular order. That way, the user still asks for pin 0 which will, due to the array, corresponds to its first element. Here it would be 5.<br><br>Hope I Helped,<br>TheFreeElectron
<p>please help me, where do i add the files in the zip folder to</p>
<p>Thank you for answering! So would an example of that be near the top?</p><p>0 = 5</p><p>1 = 6</p><p>etc?</p><p>Thanks.</p>
<p>That's it. So instead of putting $pin (from 0 to 7) in the exec function, you put $array[ $pin ] (array for 5 to 13)</p>
<p>Sorry if I am not getting this but here is how my exec line reads in gpio.php</p><p>exec (&quot;gpio read &quot;.$pic, $status, $return );</p><p>I don't get at all what you have said to swap out into this line or where 0-7 are getting pulled from this line to begin with? Here is the entire gpio.php file if you could replace in here exactly how to add these random pins for easy example: 0,2,3,5,8,9,12,13.</p><p>Thanks again for your time~!</p><p>&lt;?php</p><p>//TheFreeElectron 2015, <a href="https://www.instructables.com/member/TheFreeElectron/" rel="nofollow"> https://www.instructables.com/member/TheFreeElectr...</a></p><p>//This page is requested by the JavaScript, it updates the pin's status and then print it</p><p>//Getting and using values</p><p>if (isset ( $_GET[&quot;pic&quot;] )) {</p><p> $pic = strip_tags ($_GET[&quot;pic&quot;]);</p><p> //test if value is a number</p><p> if ( (is_numeric($pic)) &amp;&amp; ($pic &lt;= 7) &amp;&amp; ($pic &gt;= 0) ) {</p><p> //set the gpio's mode to output</p><p> system(&quot;gpio mode &quot;.$pic.&quot; out&quot;);</p><p> //reading pin's status</p><p> exec (&quot;gpio read &quot;.$pic, $status, $return );</p><p> //set the gpio to high/low</p><p> if ($status[0] == &quot;0&quot; ) { $status[0] = &quot;1&quot;; }</p><p> else if ($status[0] == &quot;1&quot; ) { $status[0] = &quot;0&quot;; }</p><p> system(&quot;gpio write &quot;.$pic.&quot; &quot;.$status[0] );</p><p> //reading pin's status</p><p> exec (&quot;gpio read &quot;.$pic, $status, $return );</p><p> //print it to the client on the response</p><p> echo($status[0]);</p><p> }</p><p> else { echo (&quot;fail&quot;); }</p><p>} //print fail if cannot use values</p><p>else { echo (&quot;fail&quot;); }</p><p>?&gt;</p>
<p>At the beginning of the code, create $array = [5,...,13]<br>Then in the system and exec commands, replace $pic by $array[$pic]</p>
<p>Ok, I did exactly as you said and now the page errors if you try to click on a on/off button. This is to the point of going to look for another instructable. </p><p>I edited to what you said as you can see below. I am not sure why you would not just post a complete example to get this simple question out of the way.</p><p>&lt;?php</p><p>//TheFreeElectron 2015, <a href="https://www.instructables.com/member/TheFreeElectron/" rel="nofollow"> https://www.instructables.com/member/TheFreeElectr...</a></p><p>//This page is requested by the JavaScript, it updates the pin's status and then print it</p><p>//Getting and using values</p><p>if (isset ( $_GET[&quot;pic&quot;] )) {</p><p>$pic = strip_tags ($_GET[&quot;pic&quot;]);</p><p>$array = [0,27,2,3,4,5,6,7]</p><p>//test if value is a number</p><p>if ( (is_numeric($pic)) &amp;&amp; ($pic &lt;= 7) &amp;&amp; ($pic &gt;= 0) ) {</p><p>//set the gpio's mode to output</p><p>system(&quot;gpio mode &quot;.$array[$pic].&quot; out&quot;);</p><p>//reading pin's status</p><p>exec (&quot;gpio read &quot;.$array[$pic], $status, $return );</p><p>//set the gpio to high/low</p><p>if ($status[0] == &quot;0&quot; ) { $status[0] = &quot;1&quot;; }</p><p>else if ($status[0] == &quot;1&quot; ) { $status[0] = &quot;0&quot;; }</p><p>system(&quot;gpio write &quot;.$array[$pic].&quot; &quot;.$status[0] );</p><p>//reading pin's status</p><p>exec (&quot;gpio read &quot;.$array[$pic], $status, $return );</p><p>//print it to the client on the response</p><p>echo($status[0]);</p><p>}</p><p>else { echo (&quot;fail&quot;); }</p><p>} //print fail if cannot use values</p><p>else { echo (&quot;fail&quot;); }</p><p>?&gt;</p>
<p>Try to ask directly for /gpio.php?pic=0 in your browser to see what it gives you. In function of that you should be able to troubleshoot the error: print variables, try separate commands, etc, simply do what a programmer would do.<br><br>If you want to look for another instructable, you are obviously absolutely free.</p>
<p>more headache than it's worth.. thank you anyway. Really too bad you couldn't have just answered differently to solve vs idk what. How hard would it have been for you to just look at the code I posted and corrected it? If we were coders we likely wouldn't be on this site and if you just confuse people you are not helping them learn.. </p>
<p>You know I actually signed up for this site just so I could reply to your post. I find it frustrating that after this guys spends all that time getting this documented and written up that you can't spend a little time troubleshooting your own issue. Having been a programmer for 20+ years I have found that when there is an issue with my code it is very often a missing semi-colon or some typo or the like. The first thing you should have learned with DIY (Do It Yourself) projects is that there are hundreds of projects out there that will be close do what you want to do, but you might need to spend a little time on your own playing with it to find out how to do exactly what you want to do. Learning isn't always easy and you will find it may not always fun. But in the end after you have spent the time troubleshooting it I promise it will be worth the time learning. Especially when someone like this is pointing the way. It is when you are on your own in uncharted territory that really causes you to pause and think if this might be beyond your capabilities. The hardest part is sometimes you have to go back to the beginning and start all over to really find your issue. Good luck, I am sure if you spend just a little time you will figure it out!</p>
<p>You really need to take a look at yourself. This is an excellent tutorial, and the author has been extremely helpful to you and many others.</p><p>Helping them learn != doing it for them. </p><p>Be nice!</p>
<p>I'm not sure I am understanding how to use various GPIO pins that are not in any sequence... </p><p>So $array = [5,13,19,18,22] would be OK? and $pic is a mystery.. but the same?</p>
<p>where do i add these files? to which place</p>
<p>Hello there,</p><p>I'm pretty new to this sort of thing, and got lost right away on step 1. I'm not sure</p><p>a) Where I can obtain these materials</p><p>b) What do to (ex. connect what to what)</p><p>I have installed WiringPi</p><p>Thanks</p>
<p>Hi. this is awesome project. Thanks for ur guide in this project. I've been waiting for ur next great project. </p>
<p>thx in advance for this great project</p><p>however i neeed to read some input pins stutas with green if high and red if low .... is it possible to help me .</p>
No problem, it'll always be a pleasure.<br>Actually, pin status is read and updated every time you click a button.<br>What you can do is to create a web page with 8 indicators and a JavaScript routine sending a request to the server, every second for example. Every time the server gets that request, a PHP script sets all pins as inputs, reads their status then prints it back to the client. Once the JS received the response, it updates the 8 indicators. If you have some experience in JS and PHP, it's easy as pie.<br><br>Hope I helped,<br>TheFreeElectron
<p>Hi can you make a script for a single pin / LED on a preset pin ? Thank you</p>
<p>Sure, I've made an instructable how to control Single LED, you can see at my blog</p><p>http://engineer2you.blogspot.com/2016/09/raspberry-gpio-from-phone.html</p>
<p>This is a cracking Instructable, and I can see me using it for much more than I am at present.</p><p>I have a couple of SkyHD boxes that (typically) crash from time to time, and Sky's solution is to pull the power cord. When the boxes are mounted in a busy rack, this isn't quite so easy.</p><p>I have made some changes, including paring the UI down to 2 circuits and adding a little text here and there so my other half can understand it, as well as using my own images.</p><p>All I need to do now is mount it in a neat enclosure.</p><p>Good work TheFreeElectron!!</p>
<p>Hi did you configured the script to work with only one pin ? HOW !? i'm killing myself to get it to work with only just GPIO 27 ... </p>
<p>Very nice! I see there a very practical and useful application! With, by the way, a nice and clean interface.<br>Good work to you too!</p>
<p>I made it. It was very interesting, but i research use internet instead wifi.</p><p>Please help me</p>
<p>Nice instructable, base on your instruction, i made remote light switch through phone.</p><p>Anyone interested this project, please visit my blog: </p><p>http://engineer2you.blogspot.com/2016/06/raspberry-pi-remote-light-switch.html</p>
<p>Have been trying to setup a web interface for the past few days. Found a few but none of them really worked for some or the other reason. This is the only one which worked the first time through! Amazing.Thank you so much.</p>
<p>hi, nice project.. i want to ask. how to add password to active each button? how the about the code... </p>
About This Instructable
652,094views
1,416favorites
License:
More by TheFreeElectron:Simple and intuitive web interface for your Raspberry Pi
Add instructable to:
