Simple Arduino Robot for Less Than 10€
Introduction: Simple Arduino Robot for Less Than 10€
Hello, In this tutorial we will build a simple robot for less than 10 €. Do not expect any miracles from it. It can serve as a toy or as an aid to learning programming and robotics. Thanks to its 2 sensors it can operate in two modes. In the first mode it is able to avoid obstacles using ultrasonic sensor SR04. In the second mode it can follow the line marked on the floor using IR sensor. Enjoy!
Step 1: Components and Tools
To build the robot we need these parts and tools.
- Arduino nano with USB cable 1x
- Micro servo 2x
- Ultrasonic sensor SR04 1x
- IR infrared obstacle avoidance sensor 1x
- Robot ball wheel 1x
- 9V batery conector 2x
- 220 ohm resistor 4x
- 9V batery 2x
- Cable female female 8 x
- Cable male female 6x
- Power switch 1X
- Heavy cardboard paper 1x
- scissors
- sharp blade
- ruler
- compasses
- silicon melting gun
- iron solder
- pen
The first thing to be done is to adjust servo motors to 360 degree rotation. This can be achieved by using this tutorial:
Step 2: Robot Schematic Diagram
This schematic diagram shows how to connect parts.
Step 3: Cardboard Parts
As a building material, I used hard cardboard, because it was the only material I had at the moment. If you have a more rigid material, you can use it as well.
Step 4: Build Wheels
Since the robot does not have the wheels yet, we should build them. I used four pieces of cardboard in the shape of a circle, that I glued together by using silicone. I put silicone also around the perimeter, so the wheels can have a greater resistance. Finally, I stuck to the wheels terminations servomotor. And the wheels are finished.
Step 5: Build Chassis
1. In the first step in making of the chassis take cardboard in the shape of a square and stick two servo motors on the sides.
2. Then glue the IR sensor to the prepared hole.
3. Glue Arduino Nano into the middle.
4. On the bottom stick robot wheel ball.
5. Two 9V cable connector solder parallel to each other. Switch solder to the voltage. From grounding we bring out two connectors for ultrasonic and IR sensor
6. Glue the switch on the chassis
7.Since we do not use a breadboard, we bring out four voltage connectors(2 x Male pin servo , 2 x Female pin sensor) from VCC. From GND bring out 2 GND male connectors for servo.
Now we can test chassis.
Test code:
Step 6: Robot Case
In this step, we put the ultrasonic sensor into the holes. Then stick over robot´s case into the cube. We connect the ultrasonic sensor according to the schematic diagram.
Step 7: Final Robot
This is how the final robot looks like. Let's test it.
Step 8: Robot Avoiding Obstacles
We load a program for obstacle avoidance into the robot.
Step 9: Robot Follow Line
We load a program into the robot to track a line
  • Epilog Challenge 9
    Epilog Challenge 9
  • Paper Contest 2018
    Paper Contest 2018
  • Pocket-Sized Contest
Nice robot. I was just wondering how the servos can move the robot forward if they only have a range of 180 degrees. Are they continuous rotation servos?
I'm a french guy and also a robotic newbie, I don't understand something ,
so, I have a question for you , How did you connect servos to the rest of the parts,
Can you show me a picture with all wires and components please ?
( I know that you make a diagram but It's isn't specific enough for me : x )
This is fantastic! Thanks for sharing!
good one but why use servo u also use a dc motor i think..but i am not expert...
They are cheaper and are easier to control with Arduino. The idea was that the main components were cheaper than 10 €.
Nice work, simple and polyvalent :)
