I ride a fairly heavy bike, and realized I never used the largest gear on the front derailleur. I decided to replace it with a smooth plate, which acts a chain guard. I made this at TechShop.
Remove these ads by
Signing UpStep 1: Mount the chain ring on the lathe
Since I had access to a metal lathe at TechShop, I decided that was the tool I wanted to use. I used the four jaw chuck on the metal lathe, since this crank set uses four spokes to locate the gears. It is important to center the part when using a four jaw chuck, hence the dial gauge on the left in the photo. Centering is done via small adjustments to each of the jaws, measuring the runout between adjustments. This was by far the longest step in the process.
Make sure the chain ring is held in tightly, but not too tight or the gear will flex out of round.
Visit Our Store »
Go Pro Today »
I happen to read this as my chain guard just fell off. I always use the highest gear, but there are bolts for a crap plastic chain guard. I will see about making a new one and whether there is an instructable there. Thanks for sharing. (ps - is the Tech Shop a Hackerspace of sorts?)
my bike chain has got cover but even that cover gets oily and black and turns my jeans to trash.
Personally I don't see the use in this, as I use my outer gear, but to each their own.
You'd also need to adjust/disable the front derailer so as to not accidently pop the chain out over that I would think.
Also - I plan to remove the front derailer at some point, since I don't use it. And while I'm at it I will shorten the chain, since it's a bit droopy.
thanks for the comments!
This is a very detailed article on bicycle gearing, which you may not want to read: http://www.kenkifer.com/bikepages/touring/gears.htm
This, however, is a simple calculator so that you can find out which gain ratios your bike has and which order you should shift between them in: http://sheldonbrown.com/gears/
This fellow's web site has a wealth of information to help with other cycling projects as well.
