3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Simple cable earphone or headphone organiser
This instructable will show you how you can use an old credit card, or similar, to make a simple earbud organiser.
Step 1
Find an old plastic card of some type. I used an expired gift credit card.
Commercial organisers tend to be too small for my liking, leaving the cable with a permanent coil after use. I found a credit card to be just the right length.
I cut out a notch at the top and bottom about 10mm deep. If you're wrapping a much longer cable than a set of earbuds or similar, make this deeper to keep the cable. There is no harm in doing 10mm and testing it first, as you can always cut it more!
Secondly, on the side right in the middle, cut a notch about 3 times wider and deeper than the cable you're going to use.
I bent the cutouts backwards to make a smooth corner for the cable, but if you want to store this card in your wallet, you'll want to cut the notches completely out so the card is perfectly flat afterwards. Your call.
It should look something like this:
11 comments
Nov 9, 2011. 6:31 PMRadBear says:
I made four of these for the earbuds and other cables I use with my Kindle. Very handy! Keeps the contents of the case I use to transport the Kindle and accessories all nice and orderly. Great project!
Feb 20, 2012. 2:12 PMRadBear says:
I made a sligtly different version for the wall wart cord that came with my Kindle Fire. I cut a couple of holes in the card to hold the plug prongs and cut a notch in the end of the card to accommodate the cord. Then I wrapped the cord around the wart and card. (see sttached pics)
Feb 20, 2012. 6:16 PMRadBear says:
I don't think it is your account status. It appears the epics didn't upload due to user error. Here's my second attempt.
Nov 15, 2011. 11:13 AMtimwikander says:
clever use of material. although...you still have to unwrap your wire to get it back off the card.
Nov 15, 2011. 9:58 PMtimwikander says:
ha fair enough.
Nov 5, 2011. 6:20 PM15zhangfra says:
nice one, my earbuds are always getting tangled with my keys in my pocket, i'll have to try this out.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:steve.rand
