3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Simple, cheap, portable laptop stand/cooler
This is a super-easy, low-cost project that anyone can do. This laptop stand/cooler can be made for any size or any brand laptop (I made mine for a 13.3 inch MacBook).
Step 1Materials List
Materials List
You will need:
PVC (about 1 inch size)
Grippy pad (not sure what it's called - you will recognize it in the picture)
Hot glue gun
Hack saw (or similar)
Tape measure
18 comments
Jun 7, 2010. 8:52 AMkhalidmahida says:
seems to be very easy, what is grippy pad? any alternative
Aug 14, 2010. 2:07 PMTylerBeau says:
I think another user called it "marco mat" but it can be found just about anywhere... dollar store, Target, Walmart, grocery store, etc. It's normally used to prevent rugs from slipping on hardwood floors or placed in kitchen drawers.
Jul 19, 2010. 4:56 AMbigfunkychiken says:
it is what you put under rugs to keep them from sliding
Aug 26, 2009. 1:23 PME_MAN says:
This is Great! Simple, Cheap and Easy! you could buy a cheap large capacity flash drive from http://www.ecost.com and add a usb extension cable, an external storage device. Maybe do the same with a small fan!
Jun 20, 2009. 6:13 PMthaCrab says:
what about installing a small 5v (usb) fan IN the pipe & having a hole in the centre of the pipe so air is cooling the under side ,
Jul 1, 2009. 11:13 PMLittleWolf says:
We could add LEDs too! A storage compartment! Gentlemen, we can rebuild it; we have the technology.
Jul 6, 2009. 3:42 PMManch42 says:
Yeah! And Bluetooth! Everything is better with Bluetooth... xD
Aug 21, 2009. 9:24 AMTv1996 says:
Don't forget the wifi card!
Jul 8, 2009. 11:42 PMLittleWolf says:
A crumb catcher, a motion sensor!
Aug 23, 2009. 7:13 AMbanner229 says:
external harddrive!
Jun 11, 2009. 8:59 PMWolf Seril says:
I wouldn't exactly call it a "cooler", myself, but ok.
Jun 5, 2009. 2:57 PMmunchman says:
Nice! Will do this weekend, probably!
Jun 3, 2009. 7:10 PMlemonbar77 says:
Brilliant! I think that stuff is drawer/cabinet liner. Pretty sure I've seen it at dollar stores. This is a very nice, practical and inexpensive solution. Thank you.
Jun 5, 2009. 12:37 PMsgsidekick says:
Yes. That stuff started out as shelf liner, but has been used for any number of things. I use a small bit to keep my cutting board from sliding when I'm trying to slice things. I also use it to keep my trackball mouse from sliding around if I get too enthusiastic in some of my games.
Jun 5, 2009. 8:49 AMkirnex says:
Thought: use a larger diameter PVC pipe, thin out the tucked in edges, and you can run your power cord through the pipe. Dunno about you, but mine in located on the left, but when working, often needs to be plugged into an outlet to the right. Running it through the back of this is a perfect solution. I'm going to modify this into a lap pad. :)
Jun 4, 2009. 6:38 PMKedaDibandion says:
Nice. That looks easy enough to do. Now I just need to find a laptop...
Jun 3, 2009. 9:49 PMpmac93 says:
The grippy pad is called marco mat
Jun 3, 2009. 8:25 PMmweston says:
Great, I like it - simple and elegant, I think that liner can be used for a lot of other application too, I use it to keep my laptop from sliding on my desk (drafters desk), and it works very well.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:TyBeau
