I only had one extra stereo speaker, so I only made it mono. If you have two speakers, just make this twice and you have a stereo amp.
The name of the game here is simple, but feel free to make it more complicated and nicer if you feeling the urge.
I also included steps on how to fit this in a army surplus case and make it a portable amp for your ipod.
UPDATE: I have kits
I have been asked for parts and where to get them a lot since I posted this. If anyone is interested I have kits now with everything you need to build this for $50 + $5 shipping.
Send me a PM with your email address if you are interested.
Thanks,
-Joe
Remove these ads by
Signing UpStep 1Parts
-Radio Shack Phono(RCA) Jack 274-346 $3.99
-4 small nuts and bolts.
-Radio Shack DC Power Jack - 274-1576 $2.59
-Any old 8-12V wall wart that fits the power jack. $Free
-Radio Shack project box 270-283 $3.99 .
-Velleman 7W Mono Amp K4001 $10.00
If you make the portable model
-2 9V snap connectors 270-324
-2 9v batteries $5.00
-Power switch 275-612 $2.99
-470 ohm resistor
-LED
-Army Surplus box ??? I used a signal light box.
-Old computer speaker
-Old earphones or some old 1/8" stereo jack headphone jack.
-Piece of screen
-4 nuts and bolts
Tools:
Drill
Soldering Iron
Tin Nibbler
Screw drivers
Wire strippers
Needle Nose Pliers
This is much more of putting together all working pieces muck more like a jigsaw puzzle.
Its is much better if there was an schematics like a stereo amplfier with sub woofer output power by DC 12 volts that has an ouput of 200w per channel.
I like this iPod amp. This is what real hobbyists / enthusiasts are made off!
I used to like tinkering around with electronics and making various devices.
Tony
-Joe
I have been asked for parts and where to get them a lot since I posted this. If anyone is interested I have kits now with everything you need to build this for $60 + shipping.
Thanks,
-Joe
The very quiet bit is still there, but it's amplified using the batteries (doesn't drain your ipod, big plus also :P)
I've found that many computer speakers can be greatly improved by putting them in a good box :)
That said, I hate to tell you this, but your idea has a problem. The amp you are using is mono, and you say that you have attached both channels from the iPod into the one input connector on the amp.
Imagine this - you are listening to a tune on the iPod, and that tune for whatever reason is only on one channel, either left or right (Pink Floyd does this sometimes, so that it seems like the music is coming from the right, then the left, etc). This means that there is high voltage on one channel, and zero volts on the other. When you connect high voltage to zero voltage, that is called a SHORT CIRCUIT - the left channel is shorting to the right or vice versa, and it stresses the circuit. In general, you should NEVER attach two outputs together without some circuitry in between, or you may see fireworks in the future.
The iPod is probably designed to handle some shorts, but if I were you, I'd put resistors in series with each individual channel , and then a resistor between the amp's input and neutral. This is called an isolation pad, and it protects the iPod's outputs. I'd use maybe 2.2Kohms for each of the three resistors (you should experiment with this on a breadboard - you may not need the resistor between input and ground depending on the amp's impedance). Granted, it will attenuate the signal, so it will sound softer, but if you have a good strong amp, just crank it a little more. At least then the iPod will be protected.
Once again, hell of a good idea for iPod use in rough conditions. You could even waterproof that that thing!
