3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Simple iPod USB charger
In this instructable, I will show you how to build a simple iPod charger! It's easy to make and modify, and is built to charge as fast as an official Apple USB charger.
Before we start, here's a little note:
DISCLAIMER: I'm not responsible for any damage of any kind to humans, materials, etc. by the use
and construction of this device. By using this device, you must agree to this condition. Otherwise, you
musn't use this device.
Sorry for some bad pictures, but they seem to went through a pixelation filter while uploading. You can see the original pictures by clicking the "i" in the top left corner of the picture.
Also, sorry for my bad English.
Feel free to comment or to pose questions!
Are you ready? Let's get started!
EDIT: added pcb in Eagle format.
Step 1The things you will need
  • last photo ←
To make this charger, you need this (common available) components:
-a 7805 voltage regulator
-a 1000µF, 35V electrolytic capacitor
-a 4.7µF, 15V electrolytic capacitor
 -2* 100nF capacitors
 -2* 5k (multiturn) trimmers
 -a USB connector, type A, female; or you can demolish an old USB cable
-a power supply that can provide at least 7.5V, and 1200mA
-a DC jack
-wires
-sticky, rubber feet
-a prototyping board
-solder: use 60/40, raisin core solder
-a 5K/W or better heatsink with M3 mounting bolts
-silicon cooling paste
And this tools:
-a soldering iron
-a sponge (to clean your soldering iron)
-diagonal cutters
-tweezers may be handy
-a iron saw
-a basic range of screwdrivers
-a screw or a drill
-a solder sucker or desoldering braid
-a basic multimeter that can measure resistance, and DC-voltage
You will also need this skills:
-you must know how to solder, if not check this video: http://www.youtube.com/watch?v=I_NU2ruzyc4
-basic electronic skills
-you must know how to use your multimeter
14 comments
Apr 17, 2012. 2:43 PMiApple guy says:
A couple Queshtons:
1. Will this work with iDevices that need power through the data pins
2. Is there enough current to charge an iPad. If not how can I make it able to charge a iPad... Schematic?
Apr 18, 2012. 8:26 PMiApple guy says:
Should I post a picture of the side of the charger that has all the info on it amp, volt, current, etc.?
May 26, 2011. 2:54 PMakimirza says:
hi
what cooling paste?
It should be silicone paste...
Apr 20, 2011. 9:14 PMsilencekilla says:
Will this work with the iPod Touch 4G?
Apr 22, 2011. 7:42 PMsilencekilla says:
thank-you that was one of the most informative reply's i've ever gotten on here and 5*'s for the instructable.
May 10, 2011. 9:29 AMsilencekilla says:
Do you have any availiable PCB files for this project? If so where can i find them. I am also subscribing to you here on instructables and hope to see more fantastic electronics projects like this one.
P.S. ONE FINAL QUESTION (.........for now ) Where did you find such a big heatsink i've been looking for ones like thoughs for a while now and havent found a single one anywhere. Please let me know. Thank You
May 6, 2011. 8:23 PMinhaos says:
(removed by author or community request)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:heatseeker96
