I am posting this as I could not find any other cardboard tables on Instructables that can be taken apart (for storage or transporting). I made this one temporarily for my kids to use prior to a recent move, and it has now been repurposed as a smaller end table for a spare bedroom.
*I have uploaded a Sketchup 3D file used for the diagrams.
Materials used
- One large 3-ply cardboard box (80W x 64H x 23D cm)
- Wood glue (any normal glue should suffice)
Tools used
- Pencil
- Straight edge (solid metal ruler)
- Utility knife (boxcutter with breakable blades)
- Cutting mat (I used the self-healing type)
Remove these ads by
Signing UpStep 1Fitting the layout onto the cardboard box
This particular box was made from 3-ply cardboard which is quite heavy duty (7.5 mm thick). Doubled up it was 1.5 cm thick.
If you are using thinner cardboard (e.g. single layer type), I would recommend using at least 3 layers so it has some strength.
*For the legs, make sure the corrugated "flutes" are vertical (if they are horizontal it can collapse easily).
In the first illustration (front of the box) you can see two tabs at the bottom of both leg pieces.
The tabs will fit into holes in the bottom of the table top, like a mortise and tenon system (see the second illustration, shows the table top, with holes for the tabs). *I did not cut out the holes for the tabs until immediately before assembling.
The horizontal support piece slots into both legs.
You can adjust the length and width of pieces to accommodate the box or cardboard pieces you have available.
Here is another example of a cardboard box that got new life as a pencil crayon holder for my daughter's 500 piece set.
