loading
Step 6: Building the Circuit: the Switch, Batteries and Potentiometer
To power your robot you are going to need a 6 volt power supply. You can use a battery case for either 4 AAs or 4 AAAs. while AAs last longer, the AAAs take up less space and are lighter. you will need a switch for obvious reasons, but be sure you use one that has no more than 3 leads on it. the pontentiometer is to keep the robot going straight when it is facing the light source, or to make sure other light sources or ambient light do not interfere. Try to get a 50k pot, but go you can go higher if you think you will need to.
Plz send youtube video of this robot
<p>you can make a simple one with 2 555 timers, 2 photo resistor ,and 2 stepper motors</p>
<p>I'd love to see that diagram if you have it swiftquail!</p>
<p>I NEED A CIRCUIT OF THAT PROJECT </p>
<p>did u get the circuit diagram of the project</p>
<p>It's the last picture on step three, I think.</p>
<p>can u send the circuit diagram of this project</p>
do somone have the circuit of the project??<br>
I dont understand tge shem... plz do someone has a good quality drawing?? plz I really want to make this Project.. thankz
it is not working . when the light is off then it should not work but is working with out light also then what is perpose<br>
Yes this is true. in the dark the robot still runs. this may seem to defeat the purpose of having a light seeking robot, however the robot is designed to seek a state of equilibrium with the light. in other words it moves until the amount of light on both LDRs is the same. That being said, in the dark with identical amounts of light on the sensors it will move straight. My suggestion to you if you don't want it to run in the dark, is to add two NPN transistors to the motors so that no power will go to them unless the light exceeds a certain level. I am going to experiment with this circuit a little bit, but if it works I will be sure to post it.
<p>how to add two npn transistors at motors.. show the schema please? and what kind of the NPN transistors that can use, what type of it?</p>
<p>hi Higgs Boson!</p><p>this robot always be running nonstop,although a little light or a lot of light.</p><p>What should i do, to make this robot stop at brightless and it running when there are some bright lights?? please help me for my school project.. please give me that modified schema, thanks before :)</p>
<p>Can I use a 9V battery for the robot, or is it strictly 6V?</p>
<p>UGH! I really REALLY wanna build this but, from the drawing (because the photos aint helpin') It looks as though power+ is going into the 555 on pin 8 AND at the end of pin 4 (reset) which is connected to a motor.....is that correct? the same thing at an end of the LDRs with a 2nd ground running from it...in addition to pin 1 having a ground from/to power...correct? Great, idea, superb on the simplicity of the parts but, sure frustrating with out clear instructions..ie step by step and/or useful circuit images. Thanks for postin' tho!</p>
<p>Yes. That's right.</p>
It would be good to see your contraption in action. Any possibility Boson? <br>
Regretfully it is no longer in one piece.
Hello im interested with your project but i'd like to know specifically what type/kind of identical motors that your pertaining to? Because i need the specs. your reply will help a lot and will be highly appreciated Thanks ! :)
Unfortunately I no longer have the exact specs on the motors, but they aren't very critical. As long as the motors that you use have identical specs so that one doesn't pull harder than the other, etc. A problem that I ran into was that the motors I used spun too fast and didn't have much torque. I fixed the problem by using a Tamiya gear box.
It's difficult to see what's above the ic when you are installing the motors, could you post a clearer picture of that?
I would...but alas this robot is no longer in my possession. Looking at the schematic should tell you everything you need to know though.
how much voltage motor should i buy for this project that is?
1.5-3v. The 6v power supply should divide the voltage well between them, but look for a slower rpm, or the motors will turn so fast that the change in speeds which is supposed to make it turn will have no affect, not to mention the issue with torque.
how much voltage motor is used <br>i have used 1.5 v motor it run very fast freely but when i put it on ground it does not run .please help me <br>
The motors just do not have enough torque. You could look for a slower motor, but I recommend buying a tamiya gear box. they are only about $10 off of amazon and should solve your problem, giving your motors a lot more torque.
A good idea would be to use a solar panel so that way it could charge itself.
If you did this then you would need to get a solar panel that can produce 6v.
Or four mini solar panels that produce 1.5v each.
Yeah that would be cool. it would find the light to charge its batteries, and then keep going. Just like a living organism looking for food.
great idea, it seems like living technology is not far off. <br>
Mwahahahahaha! I am making that.
Hi<br>Could you tell me how to modify the circuit so that the robot out to a source of infrared light instead of a normal light?<br><br>thanks
If you replaced the LDRs with phototransistors and put a visible light filter over them that should work, maybe even just putting a visible light filter over the LDRs so that more or less only IR light can get to it.
So I'm trying to build this robot and I'm kind of unsure as to what specific parts I should buy.<br><br>For the motors: Radio Shack sells motors that run about the speed you describe. (a little faster actually) but they say they are 1.5-3 volts. Can I use them because the voltage is split between two motors or will the 4 AAA batteries making 6V be too much for them.<br><br>Also, can you send a link for the specific photoresistors you used in this project? Thanks for the help.
The radio shack motors should work. (I think that is where I got my motors) but you should try to find slower, or even get a gear box. If you choose to use a gear box, I recommend using the tamiya twin motor and gear box which you can get on amazon for about $9 plus shipping. You could use any photoresistor, photo cell, cds cell and so on for this, and unless I'm mistaken I'm pretty sure radio shack sells some photo cells that would work fine for this. either way here is the link address from where I got my sensors:<br>http://www.mouser.com/ProductDetail/Unspecified/J4-805-1R/?qs=sGAEpiMZZMtMMZj6jYbQBRnn68eVuJ2u<br><br>if copying pasting the address doesn't work tell me and I will include a link in the instructable.<br><br>P. S. the 1.5-3v motors should work fine.
Ok, Thanks, I went to Radio Shack and picked up the parts. I am using a chip that read 555p and not 555cn. The package said 555cn but the chip is different i'm guessing. I thought maybe it was a manufacturer difference. Do you think it will still work?
So long as it has 555 on it it will work.
here
how can i increase a motor's torque
you could add gears, but usually you just need to buy it with more torque.
Thanks.
i also want a drawn circuit in jpeg format<br>
he wont. he is a very secretive guy (or gal???)
so please post it<br>
He is not going to post it.
I don't understand how doing it in ms paint will make it any better
Really??? for the past week ive been trying to find a light seeking robot circuit and i finally found one 2 days ago XD
:megusta:
is awsome but please give me a photo of a drawing of circuit drawn in ms paint
About This Instructable
34,270views
73favorites
License:
Bio: Science is my passion. I find myself constantly working on countless experiments, from low energy particle accelerators to good old simple electronics. I also like ... More »
More by Higgs Boson:350kv Van de Graaff Generator How to see alpha particles Simple Jacob's Ladder
Add instructable to:
