3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Simple methods for molding fiberglass and carbon fiber
Here's a couple of low cost and quick procedures I use to manufacture simple parts using fiberglass and carbon fiber. While it's not the best method for producing parts that see structural loads (some form of consolidation like vacuum bagging/pressure molding to reduce internal voids should be used for that) or parts that need to have an extremely high finish leveI, I have molded everything from simple car parts to subwoofer enclosures to costuming/theatrical props using these methods.
Step 1Materials
Clear packing tape
Blue foam insulation- available at many home improvement stores
Laminating resin- polyester resin and epoxy resin ( I use Bondo polyester resin for fiberglass and West Systems epoxy resin for carbon)
Acetone
Paint brushes- I use a short bristled brush, sometimes I just cut the bristles down to anywhere between 1/2' to 1" llength
Mold release paste wax-available from Aircraft Spruce- http://www.aircraftspruce.com
Woven fiberglass cloth and/or chopped strand mat- often called CSM
Woven carbon fiber cloth- available from Aircraft Spruce- http://www.aircraftspruce.com
3M Super 77 spray glue (optional)
Rubber gloves
Filtering mask
Please use proper safety equipment when working with resins and fibers. Carbon fibers are extremely sharp when cut and the use of resins and melting of foam can produce nasty vapors.
84 comments
1-40 of 84next »
Mar 18, 2012. 1:32 PM808Dave says:
Honus - still checking in after all these years?
Re: lost foam method:
A year or so ago, I suspected this might be a great method to make an irregularly-shaped diesel tank to add to my truck's crowded underbed spaces, so I poked around on the web for info to confirm that the sludge/goo that would result from melting the styrofoam with acetone wouldn't be a problem (thinking it would stick to insides of tank, leave a residue, etc.) I didn't stumble across your instructable then - but a major web-retailer of resin/materials said it /would/ be a problem, and advised me not to do it. Your experience makes me think that might have been bad advice.
Would you say I should plan to do hand-cleaning of the interior surfaces after the initial melting - so I'd need to have good access to all interior spaces in the tank for this? If there's residue, does it seem like it's going to be forever sticky (and maybe get mixed into fuel or cause other problems), or is this a non-issue?
Also - you mentioned something about epoxy/CSM turning into a big mess? My occasional experience with almost nothing but epoxy resin in the last ten or so years is that there isn't really a problem wetting out CSM fibers, and I'd definitely prefer to work with CSM in a project like this tank, since it conforms better to irregular surfaces. Maybe this has changed since you wrote this a few years back - styrenes in polyester resin being recognized as rather nasty toxins, etc. and I hear all but replaced with epoxy in many industrial applications. I do recall how magically the fibers used to melt invisibly into the polyester resin when I used it before (doesn't do quite that with epoxy) but I've not observed any alarming lack of strength in my dabblings. Do you still avoid epoxy/CSM combination?
Mar 18, 2012. 9:18 PM808Dave says:
I might not use epoxy for a more volatile fuel, but with diesel, I have no qualms. Also, I plan to slosh the finished tank with a sealer, so it's not a problem, really.
Anyway, repeating my question about the 'lost styrofoam' process: Would you say I should plan to do hand-cleaning of the interior surfaces after the initial melting - so I'd need to have good access to all interior spaces in the tank for this? If there's residue, does it seem like it's going to be forever sticky (and maybe get mixed into fuel or cause other problems), or is this a non-issue?
Apr 23, 2012. 9:53 AMgeneral-Insano says:
as someone who has melted styrofoam before as long as you melt and clear within the same day it won't be a problem.
day 1- slippery goo similar do a runny egg(pulverize styrofoam for best results)
day 2- still slippery has a bit more body
day 3- starting to harden but still shapeable
day 4- becomes even more hard but small holes are a problem
day 5- if you get rid of the smell of gas from styrofoam makes a interesting ball once formed
Mar 30, 2011. 11:01 AMcrowd9 says:
I imagine the final product has to resist compression/suction from air forces, and not vibrate/flap during a race. How many layers of CF did you use for the parts on this project to ensure strength?
Jan 19, 2011. 5:06 AMnixnope says:
Nice info! Will need to try this!
Apr 4, 2010. 3:48 PMferrous says:
ahahahah! brilliant!
Nov 19, 2010. 5:29 PMMAXcenter says:
Woow! Nice idea, Boss...
I like the subwoofer idea! Will try to build one for my car too...
Jun 17, 2010. 8:19 AMstevo67 says:
Honus you are a huge inspiration, I love those sketches, and thank you for your most helpful and detailed instructional. I am going to hook in and make my own panels for my circuit car. Cheers from Down Under.
Jun 17, 2010. 6:55 AMBergzee24 says:
You mention using clear packing tape to seal. Is there a reason why you use clear over the brown packing tape?
May 27, 2010. 1:18 AMmrlunna13 says:
YOU ARE A TRUE MASTER CRAFTSMAN!! Wow it is the best and most descriptive instructable. I was just going through the "fiberglass" ibles, and saw yours. Couldn't stop reading, I now have to wait till tomorrow to start my cowl induction hood on my truck and center console.
Thank you so very much!!
Mr. Lunna Xiii
May 21, 2010. 11:23 AMdk-info says:
 Just came across this instructable, looks great, I am trying it this weekend. What did you do with the Acetone/foam sludge? Soap and water cleanup?.
Thanks!
David
Apr 27, 2010. 4:31 PMamcayanan says:
NICE IDEA. THANKS FOR SHARING!
Apr 4, 2010. 3:45 PMferrous says:
I was taught to coat the foam with thinned down white-glue as a sealant, then heat-wax as a mold release... do you think the packing tape method is superior? if so, why?
Apr 4, 2010. 3:41 PMferrous says:
Thanks for the tutorial! Its nice to finally see this job laid out so logically and nicely.
Mar 9, 2010. 10:10 PMcandle360 says:
I had a question about making something like a cold air intake and box. How would you make the positive mold tube? I thought of using the styrofoam but I have a problem with how to mold it. Any suggestions on what I should try to do? It's going to be a 3 inch wide intake.
Mar 20, 2010. 12:16 PMcandle360 says:
What about the box? And I plan on carbon fiber, what other steps do I have to take to cure the carbon fiber to make sure that there's no problems later with it? I've heard that if you do cure the carbon fiber right the resin used yellows and that you must also bake it.
Mar 24, 2010. 6:42 PMcandle360 says:
Alright, thanks for the information. Great instructable by the way.
Mar 21, 2010. 1:30 PMBlue_Flame says:
First off- great instructable, i've been using the wet lay-up method for a while now and its slow and tedious, even if it does get rather good results. I do have a question to ask though.........is it alright, with this method anyhow, to forego the firbreglassing at the start and just go straight to carbon?? if so, yay!! if no, why not?
Thanks again for the brilliant instructable
Nov 20, 2009. 12:40 AMdvalued says:
Wow.. I'm seriously thinking about getting a beater VW Bus and redoing the entire body in carbon fiber.. Obviously, this wouldn't be everything I need to know, but this is a great primer!
Oct 5, 2009. 7:55 PMcandle360 says:
great instructable man. I was wondering where you could buy carbon fiber cloth, maybe even blue carbon kevlar cloth. I would like to make quite a few things including a lap top cover, full ram cold air intake kit, and a speaker box
Oct 5, 2009. 7:56 PMcandle360 says:
haha, sorry. read into it a little more and saw your links. thanks man!!
Sep 29, 2009. 1:28 PMR4NS0M says:
I agree with everyone! This is one of the clearest and most concise instructables I have come across so far. I'll be honest, I wasn't searching for fiberglass molding methods when your instructable surfaced, but now I am anxiously intrigued and looking forward to experimenting! thank you very much! :0)
Jul 8, 2009. 1:31 PMCementTruck says:
I just did my first attempt at a combination fiberglass seat pan/rear fender for my motorcycle and am not happy with my work at all. The cured fiberglass is not as stiff as I had hoped, even with 4 layers of mat and plenty of resin. I applied the apropriate amount of hardener to the resin for the ambient temperature as the table on the side side of the resin container specified. Do I need to apply more fiberglass layers? More hardener? More Resin? Does more hardener make the resin harder, or does it make it cure faster? Please help!!!
Aug 9, 2009. 10:05 PMThenwcp says:
I agree with Honus.. more layers will make a harder mold, also going with what he first mentioned about load bearing parts. Vacuum sealing will help. Get some large plastic sheets (you can get some at home depot or lowes it's used to keep floors clean when your painting walls) have the fiberglass on the mold and make kind of an envelope with the plastic sealing the ends with duct tape except for one corner. stick the hose of a shop vac in the corner and seal it with duct tape. It's okay if it's not perfectly air tight, but within reason. The pressure compresses the fiberglass layers together making them stronger. the vacuum pressure isn't large but think that even if it's only 5psi vacuum that's 5 pounds sitting on every square inch so on a 9ft(squared) area that's 6480 Lbs pressing on that surface area.
9ft(squared)= 1296 square inches therefore 5lbs/inch squared*1296 square inches = 6480 Lbs
Aug 10, 2009. 9:11 AMCementTruck says:
Thanks Thenwcp. I have used 4 layers of woven cloth and resin. I'll try your solution of the vacuum on another project, but I think I'll just go back to good old fashioned steel and welding for now. I'll do the fiberglass to make the thing pretty, but not for structure. Thanks again to both of you.
Aug 9, 2009. 10:13 PMThenwcp says:
oh and I almost forgot... the resin will not stick to the plastic sheeting
May 28, 2009. 6:22 AMcory.smith says:
Sweet action! I have done a lot of fiberglass, carbon and kevlar work, and have never really been able to explain the processes this effectively! Nice! I really like the subwoofer in the tire. I might have to try that!
Aug 9, 2009. 10:09 PMThenwcp says:
Another good one is the 8" sub under the seat, perfect for people who like the thump but don't want to worry so much about "disturbing the peace"
1-40 of 84next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
621
Author:Honus(Multi-Bot)
I'm a former bicycle industry designer turned professional jeweler. I like working with my hands and am happiest when I'm in the shop building my creations. If you need help with your project just let...
more »
