3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Simple methods for molding fiberglass and carbon fiber
Step 3Method#2- lost foam molding
I used this method to create an air duct for the oil cooler on a friend's Porsche GT5R racecar. This is a very quick and easy way to mold a hollow component or a part that has severe undercuts that would not alllow it to be molded in a single piece female mold.
The first step is to cut a pattern from blue insulation foam and wrap it with clear packing tape.
Next, cover the taped pattern with a mold release wax.
Now cover the pattern with woven fiberglass cloth and wet out the resin. Make sure to leave a section uncovered- this is where the foam will be melted.
After the resin has cured, melt out the foam by pouring acetone on the uncovered section (note that in drawing #4 it says kerosene- this is incorrect). Make sure you have a decent sized tray or bucket under your part- this will get messy! As the foam melts you can reach into your hollow part and pull out the packing tape and you are left with a hollow molding.
17 comments
Jun 17, 2010. 8:19 AMstevo67 says:
Honus you are a huge inspiration, I love those sketches, and thank you for your most helpful and detailed instructional. I am going to hook in and make my own panels for my circuit car. Cheers from Down Under.
Jun 17, 2010. 6:55 AMBergzee24 says:
You mention using clear packing tape to seal. Is there a reason why you use clear over the brown packing tape?
May 21, 2010. 11:23 AMdk-info says:
 Just came across this instructable, looks great, I am trying it this weekend. What did you do with the Acetone/foam sludge? Soap and water cleanup?.
Thanks!
David
Apr 4, 2010. 3:45 PMferrous says:
I was taught to coat the foam with thinned down white-glue as a sealant, then heat-wax as a mold release... do you think the packing tape method is superior? if so, why?
Sep 29, 2009. 1:28 PMR4NS0M says:
I agree with everyone! This is one of the clearest and most concise instructables I have come across so far. I'll be honest, I wasn't searching for fiberglass molding methods when your instructable surfaced, but now I am anxiously intrigued and looking forward to experimenting! thank you very much! :0)
May 31, 2009. 4:46 PMlatemtech says:
I been thinking about doing fiberglass project for a long time and never got around to it. then I started getting the materials I needed to get started on a fiberglass project. I decided to make a hood scoop for my mazda millenia. It was to have a venturi tube inside (cone shaped) and I couldnt figure out how to cast one until I came across your instructable. Thank you so much for this! One question, do you use any syraform? and where do you get it? I be sure to post an instructables on making your own hood scoop, that for sure!
May 29, 2009. 12:21 PMpantonpride says:
This "how-to" has probably been the most helpful one I have seen to date! Thank you SO MUCH for your in-depth illustrations and step-by-step instructions. I have wanted to play with fiberglass for so long but have had no success on finding someone to teach me. Once again, thanks man!
May 8, 2009. 10:58 PMBluesRider says:
Shortshift,I'd like to see a tutorial on making a bike tank from lost foam.That's a project I've been considering.Thanks!
Sep 24, 2007. 2:07 PMshortshift says:
Hey, cool that you posted this up, I like your illustrative sketches a lot, they're clear and simple to understand. I would encourage you to break these techniques into separate instructable sections just to make them more readily searchable. While they're all related they're also quite useful in and of them selves. Anyway, I was going to make a lost foam page for a motorcycle tank, but you beat me to it :) One challenge I've had is coming up with the correct patterns for cutting up glass when laying up around complex shapes. That air duct for instance; what were the glass shapes that you chose for the "crotch" section where it bifurcates into two? Seems like this could be a new instructable topic altogether... Thanks for posting.
Jun 7, 2007. 9:01 AMmf70 says:
This is a wonderful idea, but... KEROSENE? I've never seen any foam product that would dissolve in kerosene. Mind you, I HAVE melted foam with solvents by accident. The solvents have generally been really "hot" paint additives. Mark
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
621
Author:Honus(Multi-Bot)
I'm a former bicycle industry designer turned professional jeweler. I like working with my hands and am happiest when I'm in the shop building my creations. If you need help with your project just let...
more »
