3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Simple music light show (lpt led)
  • last photo ←
Really simple & cheap light-bar, powered and controlled from pc ( over lpt port ).
It will cost you something about $10-20 to build this
( I had the plexi and lpt cable for free, so I only paid $3 for led torch and $3 for nuts and bolts )
= killer raito fun for money
video in action
video from testing
In real world is even better looking because eyes are slower than digital camera, so it is glowing nicely.
Step 1What we need
What we need
8 colorful pieces of plexi-glass ( or you can use same color, they just need to be discrete, I used 10 x 7 x 0.5 cm )
2 large pieces of transparent plexi-glass ( I used 56 x 12 x 0.3 cm )
8 leds ( I ripped them off from one $3 led torch, basically use wide angle! (with 15 or 45 degree LEDs it is looking bad, use as wide as possible ), high power, white LEDs )
bolts and nuts
black spray
wires
parallel port connector ( I used one from old printer )
hack-saw
sandpapers ( 200 & 400 )
I got the small pieces actually as testing samples from a company making plexi (plexiglass.de), they gave them to me for free. Big thanks for them :-)
85 comments
1-40 of 85next »
Apr 7, 2012. 10:36 AMguddagudda2 says:
why not making it into a usb instead of the other cable because many computers don't have that connection anymore?
Jan 4, 2012. 7:13 PMshawndur says:
can you use an ethernet cable instead of the parallel port
Jun 23, 2009. 7:13 PMN1CK4ND0 says:
It would be really cool if you made it so the LED's went on when you touched the individual plates!
Aug 17, 2011. 12:11 PMbrigs164 says:
is there a way to use 10 leds?
Jul 9, 2011. 12:06 PMjgfresh says:
i made one aswell:
http://www.youtube.com/watch?v=c3PsrWNzZPI
May 2, 2011. 6:26 AMrens23 says:
do want!
Aug 9, 2009. 4:30 AMeptgrant says:
Hey quick question, I believe I've set mine up correctly, but 2 of the 8 LED's are permantly lit up. Any suggestions?
Nov 16, 2010. 2:42 PMe-vad says:
go to the settings for those two lights, and make sure the first slider isnt at 0. i had the same problem, and all i did was put them at 1.
Aug 9, 2009. 7:17 AMeptgrant says:
2 lights are lit up constantly. it would be approx. the middle 2. so weird. just wondering now if it might be windows 7...
Jun 24, 2009. 8:31 PMwes115 says:
has anyone made one with all one color? im interested to see if it would look good or just blenf into a big.. blob. idk, i dont want alot of colors so i was thinking red blue red blue red blue ya know. but thnx man this looks great still not sure how to use the programs tho im not to goos at this stuff
Nov 8, 2010. 12:09 AMsingh1234 says:
not red blue but this also looks good. made it yesterday. very awesome instructable. = )
Oct 10, 2010. 5:45 PMKruegem says:
Is there anyway to hook this up to a mac computer?
Oct 6, 2010. 8:57 AMkarthikcool90 says:
wt will happen when we use extra LED's instead of resistors ???
like making a series of 3 LED's and connecting it to the pin ???
Aug 24, 2010. 5:06 PMcomsa42 says:
I like this instructable sooo much i made my own version! And Made an instructable about it! :D http://www.instructables.com/id/LPT-BOX/
Aug 22, 2010. 11:50 AMKruegem says:
closed grit or open grit sand paper?
Jun 12, 2010. 11:33 PMComputothought says:
Think I will try that. http://www.instructables.com/id/No-solder-parallel-port-break-out/
Jun 4, 2010. 10:23 PMacepilot32 says:
could you use clear acrylic sheets with different colored LED's to get the same affect?
Jun 4, 2010. 11:48 PMacepilot32 says:
I know how to frost acrylic. Does it really matter if i use different resistors?
Jun 5, 2010. 1:29 PMacepilot32 says:
I actually don't have a port on my computer for the computer connection so I'm going to do a static version with rgb leds
Jul 6, 2009. 1:10 PMr_barnes says:
where could you buy the colored plexi glass
Sep 29, 2009. 9:52 AMrobot+more says:
could i use an USB cord
Sep 13, 2009. 4:11 AMmaroja says:
how to connect this to the winamp..? to show the light show music..
Jul 27, 2009. 9:05 AMZem says:
Is the parallel port connector male or female? Thanks.
Aug 2, 2009. 8:46 PMosgeld says:
its female on the board, so you will need a male connector
Jul 26, 2009. 2:54 PMyznaction says:
Would it be possible to use a usb Parallel port adapter with this setup?
Jul 26, 2009. 3:36 PMfwjs28 says:
a usb port would require an extra piece, like a micro-controller...a Parallel port would be possible though with a similar set up (i am no expert in electricity nor I/0 ports so don't take my word as religion )
Jul 26, 2009. 3:50 PMyznaction says:
alright, i just ask because i only have usb ports on my laptop and I know there are a few companies that sell usb to 25 pin dsub parallels adapters
Jul 26, 2009. 3:53 PMfwjs28 says:
ahh, i would try the convertor...see what you can do
Jun 9, 2009. 1:14 AMhuang.wencong says:
It would be more fun to create your own software . . Try using Visual Basic or Delphi.
Jul 18, 2009. 4:30 PMgrey House says:
If you're into python there's an extension called pyparallel that might help. There's a great example code here: http://pyserial.wiki.sourceforge.net/pyParallel
Jun 10, 2009. 9:16 PMmitch_feaster says:
Couldn't agree more. I'd like to see it in plain old C though...
Jul 13, 2009. 7:09 PMartiem85 says:
This is my first project so maybe this goes without saying but I was wondering what size wire is used for the connection between the lpt cable and LEDs and how do you terminate at both the port and LED splice points?
Jun 6, 2009. 9:25 PMcheeyah says:
It is a good idea to put in a resistor even if the supply voltage matches the rated voltage of the LED. It is there simply to limit current, so something like a 1 Ohm resistor will protect your LED's.
Jul 9, 2009. 10:42 AMscgtrp says:
The resistor is there to protect the parallel port, not the LEDs. A new motherboard is a bit more expensive than a few LEDs, and you can easily kill your parallel port (and the motherboard, if it's onboard) by drawing too much current.
1-40 of 85next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
21
Author:joudas
