Simple Reusable Fuse
552
Posted
Introduction: Simple Reusable Fuse
In this instructable i will show how to make reusable fuse.
Step 1: Tools
Scissors
Bad fuse
Wire
Drill
Drill bit
Step 2: Prepare Fuse
First you need to drill holes in fuse ends.
Step 3: Making Reusable Fuse
Strip wire.
Step 4:
Remove one thin wire from thick wire. If you put thicker wire then you will get higher amperage fuse.
Step 5:
Put that thin wire in fuse throught holes.
Step 6: You're Done.
Wrap ends of thin wire around fuse metal ends and you are ready to use it. With this wire from thick wire i get about 4A fuse.
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Gluten Free Challenge
6 Comments
How can we figure out what size wire we need for the required amperage?
By testing. Using power supply with adjustable current. You can measure wire thickness with micrometer very accurately.
You can actually heat up caps and remove them
Then just put wire inside and put caps back on
Good idea would be to test wire first to see at what amperage does it burn out or buy replacing wires for fuses
Interesting idea. Have you tested this, and does it work?
Yes i tested it and they work perfectly. Now i use only my reusable fuses for my power supply.
Yes i tested it and now i use only reusable fuses for my power supply because they are so cheap.
