Simple solar garden lamp circuit
Picture of Simple solar garden lamp circuit
This is a simple solar garden light circuit, in this case i used a 7,2V battery and a 6V solar panel but is just for showing, it could work by any other voltage for example 3,7V battery and 4V solar panel
you need a
4V solar panel from ebay
1 schottky diode 1n5817
1 rechargeable battery 3,7V lipo or 3 ni-mh
1 led
how it works?
The solar panel in a sunny day charge the battery through a diode, and block a night current from battery to panel of some mA, this is also the maximal current flowing in the led in the night because the panel is used also as a sensor, in the night his voltage drop to about 0V and its resistance in the night allow current to flow from battery to the led and it light up without burning, the current dipends on your panel type but it's about 7mA.
For more power light you could use the other schematic and add a pnp transistor like bc369 and light up 3 or more leds each with its resistance if necessary, the resistance is calculated by (Vbatt-Vled)/Current led  Volt/mA=kohm, you should use the same power for light and for solar panel.
Remember lipo batteries should not drop under 3V each cell so when the battery is low it can't light the led and lose other current, ni-mh batteries are not affect by this problem.
I hope you like it, have fun! :)
more info to my site http://elettroportale.altervista.org/Lampadagiardino.html
In place of 5817, will it be okay If I use 5819, or 5818??
suppamanIII (author)  mle ciel surfeur3 hours ago
Yes it' ok, the only difference is the maximum voltage supported
Nimmi Thakur6 months ago
Great job buddy
suppamanIII (author)  Nimmi Thakur6 months ago
Thank you friend
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
