3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Simple solar powered pocket submarine with depth control.
Step 5On the spot assembling and trimming
Before you start trimming you should decide if you are going to use the "periscope style" depth control explained in the last step. If so, add it now, in order to take in account the correct total weight when trimming.
Assemble the parts as shown in the picture. Put the sub in the water. Make sure the motor is filled wit water before starting to trim. Either tap on it with any holes in the motor positioned at the top, or if possible place it under a running tap with one of the openings. A little air left in the motor is not that bad, but to much will make you "overtrim" and your sub risks not surfacing anymore once the air finally does escape from the motor when running.
The last picture shows how to trim (I did it in a bucket for convenience). Once the solar panel catches some sun your sub will run, for the moment remaining at the surface. To dive check out the next step. If you accidently "overtrim", having the sub dive/sink even without running forward, you can always add some floating material back again. Glue it with hot melt or a little super glue, or slide it firmly under the "clip" formed by the solar module.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
142
Author:masynmachien(land, sea, air and space)
My main hobby is developing creative workshops for children. Since several years now I have been organising those, mainly voluntary at the school my daughter is attending. My workshops most often invo...
more »
