Simple soldering jig
I often have to solder up a bunch of PCBs that are the same size, but have a bunch of fiddly components on them.
To save time and frustration, I decided to re-purpose a used chewing gum tin to make a jig so I could solder multiple boards at once and keep my components from moving about.
Step 1Prep the tin
Prep the tin
Choose a tin that's bigger than your PCB. I chose to use a chewing gum tin since 3 of my PCBs just fit, but you could use a standard sized mint tin if you have a bigger PCB.
Place your PCB on the underside of the tin and draw around it.
Make the line about 1/8" thicker on the inside to give you a cut guide.
Cut the bottom of your tin out (I used a Dremel).
DANGER! The edges will be sharp, so make sure you file and sandpaper them afterward to dull them a little. Even then, they can still cut you so use caution with your jig.
15 comments
Jan 1, 2009. 4:13 PMBerserk87 says:
nice instructable. you should make a new instructable showing a "universal" jig. plus you could use a $0.50 spounge instead of the bread :P
May 12, 2011. 1:37 AMjwoo2023 says:
he said that he used a memory foam from the pillows and cut a piece off and it looked like bread.
Jan 1, 2009. 11:44 PMtagno25 says:
Cannot use a $0.50 sponge, because they are usually NOT flame retardant.
Jan 2, 2009. 12:35 AMBerserk87 says:
bread is? lol. couldnt you soak the sponge in something? the main point being, there are better things that a piece of bread :P
Jan 2, 2009. 12:44 PMjohnson_steve says:
did you read it? it's not bread.
Jan 2, 2009. 1:08 PMBerserk87 says:
he edited it. i remember seeing "fresh baked bread" in there.
Jan 2, 2009. 2:22 PMIW5 Industries says:
no it says freahly baked bread? because he thinks it looks like bread...
Jan 2, 2009. 1:55 PMjohnson_steve says:
ahh I see. it does kind of look like bread.
Jan 5, 2009. 3:36 PMawang8 says:
I don't see the problem with using bread. When you're done all you have to do is eat the new lead-poisoning toast. Mmm...
Feb 9, 2011. 1:46 PM11tillr says:
good idea very productive
Aug 17, 2009. 10:44 PMlearning-teaching says:
Great idea, pretty cool too!
Jan 2, 2009. 1:01 AM5Volt says:
Yes, clever and a very good idea, just make sure not to breath the fumes from the sponge : it might not melt or burn but I suspect that some fumes should come off of it.
Jan 2, 2009. 7:46 AMrimar2000 says:
Very smart idea.
Jan 1, 2009. 2:46 PMPhil B says:
Clever and a very good idea, especially for making multiple copies of the same circuit board.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Instant Arcade
I'm a professional video game programmer.
