Support DIY and Instructables : Become a Pro Member Today!
Simple Melon Carving
intro
introSimple Melon Carving
This Instructable will show you how to do a simple melon carving technique that can be used to carve any type of melon. in this demo i will show you how to carve a cantaloupe.
Melon Carvings like these can be done in 5 or 10 minutes and look awesome on a buffet or to impress friends when you have a dinner party.
To View All Steps on one page,
Go Pro Today!
step 1Materials
Heres what you need left to right:Melon - in this case i used a cantaloupeFruit and vegetable carving knife- i show 2 styles here the thin bladed wooden handled knife is actually just a paring knife but it is one that has a thin blade this works pretty well for carving and is easy to find, i fou…
step 2cutting both ends of the melon
Using your Deba or chef's knife.Cut both ends of the melon take off just enough of each end to expose the flesh of the melon and make the melon where it will stand up on either end. you can see by my scrap pieces laying next to the melon you don't need to cut off much to make it stand up.
step 3time to start carving
start by sitting your melon upright (put whatever side looks the nicest upward) next in the center of the exposed area stick the U cutter about 1/2" deep and rotate this will create a circle on the top of the melon.
step 4first cut with the thai knife
take your Thai knife and lay the blade flat on top of the melon with the tip touching the edge of the circle you just made. and what you want to do is basically just cut away a ring of melon from around the center circle. the piece you remove needs to be a thin little donut you are just doing th…
step 5whip out the U cutter
first take your U cutter and plunge it about 1/2" deep at an angle (look at the picture) so that the tip of the cutter is just under your center circle.pull the cutter out and repeat immediately next to your last cutwork you way all the way around it should look like a flower when you are done
step 6time to relief the first part of the flower
Next using your Thai knife plunge into the melon parallel to the table about 1/2" down the side of the melon (look at the pic)now start working the knife all the way around the melon plunging the blade about 1" into the melon the whole way aroundonce you complete a cut all the way around the melo…
step 7everything gets very easy from this point
Ok looking at your melon you have a little flower on the top the next step is just like the last.using you U cutter plunge about 1/2" deep on the newly exposed flesh of the melon remembering to keep the cutter angled upwork your way all the way around just as you did before until you have gone a…
step 8Relieving the next ring
In this step you will do just as you did before giving relief to the top flower.only this time we are going to angle the knife down as you work your way around the flower remember slowly work you knife around the circumference of the melon going in about 1" the whole way aroundonce you complete t…
step 9now just repeat and repeat
Basically what you have to do now is just keep repeating the last steps making your plunge marksAnd then relieving the pedals with the Thai knife remember to stay angled up a bit
step 10when do i know when to stop?
You can stop making rows of pedals when you tilt the melon towards you on look at it straight on you should not be able to see any of the rind.
step 11Last step!!
Time to display figure out which side you want it to lean on. and cut a notch into the side of the rind to lean the melon on.also if any part of your melon seems to have come loose you can always make repairs using toothpicks (no one will notice, they are very easily hideable).
step 12ready for display
Ta da. that was pretty easy wasn't it. Hope you had funPlease leave some comments or pictures on how your own Melon carvings turned out
36 comments
Sep 5, 2009. 10:42 AMopcp says:
I had to change it a bit to match the tools I had at hand but here is my first melon carving. Thanks heaps for the tutorial.
http://www.flickr.com/photos/7371845@N02/3890387494/
Dec 22, 2008. 8:09 PMporcupinemamma says:
That is beautiful!! Thanks for sharing. Now, about the radish rose... First you make the cuts, and then you plunge in water. Look on the internet, there must be a diagram. It is way simpler to make than the melon-lol
Dec 17, 2008. 9:30 AMunbentcrayfish says:
oh my god that is very cool, you have too much time on your hands... nice.
Nov 21, 2008. 12:03 PMSFHandyman says:
That is really stunning. I have to try this. Thanks for posting.
Sep 26, 2008. 11:52 PMSolderguy says:
Will this work on other kind of fruit? Will this work on apples, watermelons, kiwi, bananas or anything like that?
Oct 25, 2008. 2:09 PMwatermelonhead says:
watermelons and apples, i'm guessing, will work.
Oct 22, 2008. 2:10 AMMr E Man says:
Awesome job, Can you make a radish rose? I'd like to see that done like this was.. :) I knew a Thai chef that could I only remember the trick is to put the radish in some ice water before you start.. Don't ask me the rest..
Oct 13, 2008. 10:10 PMwolfy_9005 says:
i like this :) I saw a papaya carved in bali....it looke really complex. But i guess after 20-30 years of experiece it's really easy
Oct 9, 2008. 5:06 PMColdXpook says:
Thats awesome.
Sep 27, 2008. 8:48 PMclamoring says:
Beautiful work!
Sep 26, 2008. 1:29 PMmilo0is0hot0 says:
sooooo cooool i have to try this...
Sep 26, 2008. 11:44 AMrotteneggsaresmelly says:
feckin' sweet!
Sep 26, 2008. 7:22 AMsajrs says:
it's nice to see some of the cold larder techniques on 'ibles... it's a long time since i did fruit & veg carving... kinda makes me think of picking up a melon just for the sake of getting back those skills, thanks for the reminder
Sep 26, 2008. 12:13 AMcluelesstyagi says:
awesome!
Sep 25, 2008. 5:56 PMzwild1 says:
Great ible! Nice clean and focused pics, great descriptions! I think I might try this one at some point.... Keep up the good work!
Sep 25, 2008. 5:55 PMsmashbob says:
very simple with a great turnout. artistic. good i'ble. +1
Sep 25, 2008. 5:46 PMernestoaug says:
artista
Sep 25, 2008. 5:43 PMpechka says:
Wow! (But THAT'LL be the day, when a ripe melon survives around me longer than it takes me to get rid of the seeds and then gorge myself so rapidly that I risk choking to death----ripe honeydew melons ARE worth the risk, though!)
Sep 25, 2008. 4:22 PMthesamhill says:
Hey, that's awesome! When I make a pineapple, I cut the top off and set it on the plate. Then I stack the cut up bits all around it, with whatever else. Gotta love decorative fruit. But what's with the "melons make you sick" thing? I've been eating melons forever and I've never gotten sick from them.
Sep 25, 2008. 2:41 AMthematthatter says:
you gotta be careful with melons because they are a potentially hazardous food. Unlike most fruits, melons dont have a lot of acidity to inhibit bacteria growth. So you got to make sure to scrub them down good. And keep them chilled. You dont want to give your guests 3 days of the two bucket blues :(
Sep 25, 2008. 11:42 AMjongscx says:
well, you're not REALLY supposed to eat the decorative fruit anyway... just b/c you're not sure who's been handling it, and if they assumed you were gonna eat it or now (or if they washed their hands after using the bathroom...) it is pretty tho
Sep 25, 2008. 10:04 AMPlasmana says:
Wow! That is so cool! And easy too!
Sep 24, 2008. 8:22 PMacm321 says:
Too bad I'm allergic to melons...
Sep 24, 2008. 5:52 PMpass-the-beans says:
where do you get the u cutting knife. and about how long will it take to do a mellon that size?
Sep 24, 2008. 2:33 PMwhackpak says:
very good Instructable with detailed photo's
Sep 24, 2008. 2:31 PMFreshPineSent says:
Sep 24, 2008. 1:40 PMwupme says:
In the small thumb on the homepage, i thought it was a durian. That looks awesome, i just can't come up with the time :(
Sep 24, 2008. 1:35 PMLuminousObject says:
So very awesome. Will do this.
Sep 24, 2008. 1:15 PMJellyWoo says:
that is so cool!!!!!!!!!! would look great at parties. you're very talented!
Related
