Simplest Arduino Based Sound / Lightning / Thunder Trigger
Introduction: Simplest Arduino Based Sound / Lightning / Thunder Trigger
This is the simplest sound/lightning trigger based on Arduino.
Parts needed:
1 2N3904
1 1K resistor
1 Piezo buzzer as sound sensor
1 Photodiode BPW21R for lightning trigger
1 Arduino
Step 1: Connect the black wire of Piezo to Gnd pin of Arduino
Step 2: Connect the red wire of Piezo to analog 0 (A0) of Arduino
Step 3: Load the attached sketch file to Arduino
----------------------- at this point, if you clap your hands or snap your finger, watch serial monitor -----------------------------
Step 4: Construct trigger circuit as shown in picture and connect FLASH_PIN to the one defined in sketch
Step 5: Connect a flash to the triggering circuit.
Step 6: Clap your hands or snap your fingers and watch flash goes off.
Step 7: Plug a photodiode with large sensing area, plug the positive terminal into A0 and negative terminal into Gnd
Step 8: Get a flash and set it at lowest output power and watch what happens -- it can be used as lightning trigger
Source code at github:
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Paper Contest 2018
      Paper Contest 2018
    Go to and see what can be found there... The thing works, by the way.
    No code available on link given, or any available product either, no good at all.
