3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Simplest Bird Feeder
Step 3Assembly of Feeder
Assembly of Feeder
Attach the bottom of the soda bottle back on to the top (this will be the lid that you open to add bird seed). Don't put the two soda bottle pieces together too tightly, just enough so that a bird, squirrel, or strong wind won't easily open it.
Now poke the rubber strips through the holes in the milk jug and tie a fat knot on the other side (when using rubber, almost any knot should be fat enough, just make sure it will hold). Slide the milk jug piece over the cap of the bottle (the bottle and jug I used fit perfectly, but if yours is a little bit loose, you might need to fill the space with something to keep the seed from falling out).
In order to keep the feeder from flopping over, you will need to tighten the strips on it by tying a small ring of rubber around the three lines to cleave them together. To fill/refill the feeder, this ring will simply slide up and allow you to open it.
1 comment
Jun 20, 2009. 12:20 PMvalhallasmine says:
Would this work? at end of assembly, how about sliding a washer (1/2" inner dia) down your 3 rubber strips to sinch them together. Then just slide the washer up to free the bottle for refilling? Love your Instructable -- good one!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:apccool
Teaching student, biking enthusiast and I love to reuse things, much to my girlfriend's chagrin at times...
