- 12-18v in = ~73v+ out
- Uses only 2 transistors, no IC's
- Can be made out of one CFL light bulb
- Uses fully discreet components
- 17.2kHz switching frequency
Output is only low current but could probably be used to power a small triode preamp stage (Very high impedance)
UPDATE: Thanks to "neumanngregor" for pointed out: ONLY USE ELECTROLYTIC CAPACITORS IN SERIES AS A LAST RESORT, I am not responsible to any damage caused. If possible, use properly voltage rated capacitors. Thanks :)
If you are unsure of the the inductor size, just try tweaking the oscillation capacitor until you get the highest voltage :)*
*A general rule, since this is a constant duty cycle, larger inductors will need a lower oscillation speed.
Remove these ads by
Signing UpStep 1Parts and Specs
Most standard transistors should be able to cause an avalanche on 12v but some transistors dont (as I have found out!) I find the BC337 and BC547 to breakdown perfectly.
The circuit oscillates at ~17.2kHz, nearly above the audible range.
The parts required:
TIP122 or Power Darlington transistor
BC337 or Compatible
0.1uF/100nF Ceramic Capacitor
100uF Electrolytic Capacitor (Preferable 16v if the circuit is ran on 12v but 10v should do fine)
1k resistor
Any high voltage capacitor. I used two 63v capacitors in series to double the voltage rating.
Any suitable diode with high enough voltage (1N4001 isn't high enough voltage, its rated at 50v)
An inductor with inductance between 1-5mH should be fine
You cant make more energy out of nowhere!
the TIP 122 becomes very hot just after i apply 12 v .
Is it getting short ?
Anyone who wants my circuit about V-Quadrupler is welcome...... hence I though it would power up my gun....
any schematic? Voltage doubler circuits on the web gives around 100mA which is not sufficient for motor driving. Thanks...
my god I think I have burned my TIP122....
and one more thing i didn't find TIP122 in Multisim ... is there any equivalent transistor?
thanx alot
What I'm planning to do is to slash the voltage down to about 50V, then using the LM317HVT to keep the voltage at 48V. Could you add some theory or point me to some regarding this circuit? I'd really appreciate it.
I have following doubts.
1) I couldnt get 1N4005. So i got 1N4007. Will it work ?
2) Do we have to connect the 12V battery between +12v and the ground ?
I am new to Electronics, so plz help me.
Can any one explain ?
Yep, but taking apart computer monitors is something that I don't think everybody would do. Computer monitors have much more high voltage components than a simple CFL light bulb and not make people have old CRT's at hand, I just said CFL's because there normally around the house (I can think of a few places that I have one).
BUt thinking about it, if the voltage is only ~73v and the capacitors are both rated at 63v, that gives 126v (if perfectly balanced obviously) so:
If the first capacitor was taking 80% of the voltage due to being imbalanced, that would only be 58.4v, wouldn't this be under the 63v rating?
Keep the good work and have fun.
