Simplest High Frequency PWM With NE555
Introduction: Simplest High Frequency PWM With NE555
In this instructable I will show you how I made a high frequency Pulse Width Modulator with the most famous integrated circuit the NE555.
This circuit is a good starting point in electronics for beginners because of the low amount of parts. It can be used to regulate computer fans, LEDs, motors and much more.
Step 1: Demonstration
In this video you can see the finished project.
Step 2: High Frequency Pulse Width Modulation
I did not make the video.
Well if you watched the video you should now know what a PWM is but why do we need a high frequency ?
The reason is that with low frequency pulses going to a motor, you can hear the coils switching on and off and that can be quite annoying. Imagine you set your fan to low speed in order for it to be quiet and the aerodynamic noise indeed will decrease but the noise from coils will increase making it loud again!
But if the pulses are high frequency the human ear will not hear them.
Step 3: Parts List
For this instructable you will need:
male headers (or just solder some wires)
1x - NE555
1x - 8 pin socket (optional)
4x - any general purpose diode (I used 1N4148)
1x - any power NPN transistor (I used BD139)
1x - 470pF capacitor
1x - 1 kΩ resistor
1x - 4.7 kΩ resistor
1x - Potentiometer 5kΩ to 1MΩ (I used 50kΩ) linear
Step 4: Schematic and PCB
A big advantage of this board design is that it can be plugged into the breadboard for testing.
This circuit can work on voltages from 4.5V to 16V. But if you used separate power supply for the chip and for the transistor it could be used for driving voltages higher than 16V.
The integrated circuit NE555 is wired in an astable mode(oscillator). The oscillation is determined by the size of capacitor(C1) and position of potentiometer(R3).
We have to use a transistor because the NE555 is not capable of supporting high currents to the load so the majority of current goes through transistor and not the IC. The PWM signal generated by IC switches the transistor on and off. In other words the PWM signal is amplified by the transistor.
The 1kΩ resistor(R1) limits the base emitter current, without it the path from pin 7 of the IC to transistor would act like short circuit to ground.
The 4.7kΩ resistor(R2) is a pull up resistor.
For the schematic and PCB I used a free program CadSoft Eagle which I would recommend to anyone making schematics or PCBs.
Step 5: Conclusion
This circuit is good for controlling speed of a motor but if you try to use this to dim LEDs it will work to some extent but you won't be able to fully dim the LED, although it's not that horrible, just try it yourself.
If you manage to build this project don't forget to post your results into the comments.
  • Science of Cooking
    Science of Cooking
  • Trash to Treasure
    Trash to Treasure
  • Paper Contest 2018
    Paper Contest 2018
how much fan can be used with this tool?
I've made this circuit using a 100nF capacitor since I didn't have a 470pF one. The circuit works but, the motor continuously spins (even at the slowest position) and the difference in the speed of the motor at the fastest and slowest position(of the potentiometer) is very slight. Also my transistor (BC-547) gets extremely hot and at one point bursted and gave out a lot of smoke. Why would this be happening? I have wired it properly. Also, can you tell me how does the value of the capacitor affect the PWM.
BC-547(small signal transistor) can't handle the power that the motor draws, you should use BD139 or other similiar transistor in that package.
The 100nF capacitor will lower the frequency of the oscillation and you will no longer have high frequency PWM, it may also narrow the range of RPM.
Can you also give a detailed explanation of the circuitry? The pin 3 of 555 has been connected to the middle leg of a POT, thus making it an input pin. But pin 3 of 555 is actually an output pin. I also didn't get use of diodes in the above circuit. can you also elaborate on the use of 4.7K resistor in the above circuit?
Hey guys, can anyone reply to this question of mine?
I have a small LED desk lamp with external wall wart. I'd like to stick
this in the base and replace the on/off switch with a dimmer. Will
this go way down in duty cycle (10%...) Also the one thing I can't seem
to determine is what components change as load goes up - point me to a
webpage for the maths on these?
Am I missing something? You list 4 diodes, but schematic only shows 3. It looks like maybe the missing one is used for polarity protection for the source power?
Yes you are right, now there are 4 diodes in the schematic
It was an easy build. Works great. Using an optical tach, it seems it didn't get to 100% of fan speed; but it is working perfectly in the range I need.
Thank you for the easy instructable!
if u use an 3 wire fan, u dont need to pwm on the "voltage", u can control in the "yellow" wire, its better and safe. ah, 20khz seens good for all coolers.
I have some minebea 140cfm coolers from servers, and they work great.
