Introduction: Simplest Slouchy Hat
When style meets simplicity you get this-the Simplest Slouchy Hat!
This easy crochet project is perfect for learning, teaching, gifting or selling. It would make a great addition to your holiday gift list, and because it is fast to make you will have time to make several :)
If you enjoy this pattern, please remember to vote for it in the current contests. Thank you!
Step 1: Gather Your Supplies
Supplies:
Worsted weight yarn (less than 300 yards)
I/5.5mm Crochet Hook (I like Clover Amour)
Yarn Needle
Scissors
Clover Large Pom Pom Maker (2.5" size)
Abbreviations:
Ch: chain
sl st: slip stitch
HDC: Half double crochet
BLO: back loop only
Gauge
8 rows x 16 sts = 4" square
Finished Size:
Diameter = 9"
Length = 12.5" (not including pom pom)
This hat is intended to fit toddlers. For more sizes visit www.leftinknots.com :)
Pattern Notes
Chain stitches at the beginning of rows do not count as a stitch
Step 2: Make Your Starting Chain
Tie a slip knot
Chain 49
Row 1: HDC in second ch from the hook and across the chain (you will have a total of 48 HDC stitches)
Step 3: Make Your Hat
Rows 2-36: Ch 1, working in BLO-HDC across. You will have 48 stitches in each row, and you are essetially making a large rectangle.
To seam the hat together, fold your rectangle in half so that Row 1 and 36 are touching. Slip stitch through Row 1 and 36, working them together to create the seam. In this step you are essentially creating a large tube shape. When you finish your seam, tie off your yarn and leave a long tail (approx 10")
Step 4: Finishing Touches
Cinching the top of the hat: Using a yarn needle, weave the long tail of yarn back and forth through the top edge of the hat. Pull tight and tie the yarn so that the top stays closed.
Make a pom pom. You can make them freehand, but I love the Clover Pom Pom Makers! So much easier! When you tie your pom pom, leave long tails on both sides for attaching the pom pom to the top of the hat (as pictured)
When you are finished, weave in your ends and now....
Step 5: Wear It!
Enjoy your warm, stylish and super simple hat! These can be easily adjusted in size and made for the whole family.
Find this pattern in sizes infant through adult and more free patterns on my blog www.leftinknots.com!
If you enjoyed this pattern please remember to vote for it in the current contests. Thank you!
Hats and Headpieces Challenge
Brave the Elements 2016
Made with Yarn Contest 2016
