3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Simplified 'H' Bridge
Simplified \
This is a simple circuit to control the direction of a DC motor, with the capability to turn it off.
Step 1Nothing to it...
Nothing to it...
There is really nothing much to explain. A simple switch will give you the capability to reverse and switch on/off your motor. A switch, like anything else can wear out, but with only one part to deal with, you have less of a chance of paying for a bunch of more expensive components when it comes time to replace them.
8 comments
Mar 31, 2009. 6:55 AMamando96 says:
ohh way beter than relays for sure, although for robots not the best option, but for big motors like couple hundred volts, pretty usefull :tup:
Jun 8, 2008. 12:35 PMmecfr says:
hi i can see how this will replace the H bridges. but using the same switch [three states that has on-off-on) how can i connect it to limit the current (or how many times the motor turns?) thank you in advance for your help
Aug 23, 2007. 5:29 AMunclelar says:
Would this work on an AC motor?
Dec 10, 2008. 5:17 AMWyle_E says:
It depends on what kind of AC motor. Series-wound ("universal") motors, like the ones in AC-powered portable power tools, can be reversed by reversing the connections to the brushes, but you have to get inside the motor case to do that. Reversing the connections to the whole motor won't work; that's why series motors run in one direction on AC. One simple approach is to use a permanent-magnet DC motor, a bridge rectifier and a reversing switch on the DC side of the bridge.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Pazzerz
I've been more of a thinker than a do-er but when I get going on a project, I tend to do fairly well. I've built a 30 x 60 barn with loft, and a 30 x 90 greenhouse, all by myself, several karts, air ...
more »
