3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Simulated woodgrain for metal boxes
This instructable shows how to prepare a metal box using a buffing technique that can simulate wood grain, birdseye or other finishes. The technique gives dimension to the box that adds visual depth to the surface.
It is easy to do and allows you to create a variety of nice finishes with little extra effort.
Step 1Items Needed
Items Needed
The box that I am preparing is a small cast aluminum box that typically has a rough finish in the raw. This one is similar to the Hammond 1590B.
Every aluminum box should be sanded before painting to remove the oxidized aluminum from the surface so that the paint can adhere better to the base metal.
For this type of brushed or buffed finish, I am using an abrasive wheel that mounts in a hand drill.
The red and gray wheels are similar but the latter is a finer mesh that produces a smoother finish. The material seems to be some sort of tough nylon woven fiber much like the 3M abrasive pads that are commonly available.
I bought these buffing wheels in a kit at Harbor Freight.
36 comments
Sep 29, 2011. 11:12 AMglahboo_wahbooP says:
Wow! You're the AMZ from Muzique.com! You've been filling my head with powerful knowledge for years now!! Thanks infinity+1!!
Sep 29, 2011. 11:08 AMglahboo_wahbooP says:
What program, may I ask, did you use to generate that clear template? Do you happen to make PCB layouts with it as well? I'm trying to find the right program for these purposes. The paint job looks fantastic! I will certainly follow this technique next time. Thanks!
Feb 22, 2008. 8:39 PMcraig f says:
do you also seal it with clear coat?
Mar 27, 2011. 2:50 PM-Syrus- says:
What a beauty man!
Great looking stuff ! :P
Nov 26, 2009. 5:27 PMGlockenator says:
i used this for a guitar killswitch and it matches my Solo guitar perfectley
Mar 14, 2009. 2:03 PMhillbillysurf says:
Will the buffing technique used on the cast alum. work on metal ? Thanks
Apr 10, 2009. 9:24 PMsnowpenguin says:
Aluminum is metal. You knew that right?
Dec 3, 2008. 1:38 PMpeterson0226atyahoo.com says:
thats a pretty cool idea
Jul 25, 2008. 9:39 AMsashadalton43 says:
This is sooooooooo cool!
Feb 27, 2008. 12:20 AMshop dweller says:
I like it. Very nice technique.
Feb 25, 2008. 5:12 PMnkw6 says:
Looks good but if you want to make it more convincing and happen to have a mill lying around chuck up a flycutter and play around with the autofeed. The table has to be pretty dang level but you get some sick grain effects.
Feb 22, 2008. 6:54 PMhalitus87 says:
just fyi you wont be removing the oxide layer from aluminum, as with this type of metal it forms a coherent layer around the metal protecting the rest of it from oxidation, still sand it of course i still agree thats very important
Feb 22, 2008. 7:53 AMTazzz says:
Easy solution and looks nice. Good woodworking practice however would be to make the grain run parallel to the long side on top, not across. Also the sides grain pattern should match (an extension) of the top grain.
Feb 21, 2008. 7:29 PMShocker says:
Just a comment on the box used. The box is made by Hammond as described. In Canada, I order part 1590 not 1590B. The "1590B" stands for black with an extra cost of $2.00 and the "1590" is just bare aluminum. Great supplier online is Digi-Key at digikey.com. If I order in the morning I receive product next afternoon, usually with only about a 4-8 dollar shipping charge. I have found that paint is available from hobby shops, look for tail light paint for model cars. Shocker
Feb 21, 2008. 8:59 PMtechnodude92 says:
Awesome finishing technique. if i ever get around to making something that i can put in a box. fav'd and (+)
Feb 21, 2008. 4:37 PMrotter says:
Pretty cool finish effects. Would be interesting to do a woodgrain finish on a bike.
Feb 15, 2008. 4:46 PMGorillazMiko says:
This is actually a really awesome Instructable. Looks just awesome, awesome, this just deserves a +1 rating.
Feb 18, 2008. 11:37 AMsysadmn says:
I found some "Contact" brand adhesive vinyl at an Office Supply Store that looks just like brushed stainless steel. It works great on flat surfaces (even boxes and round hat boxes) but you have to work slowly and not create bubbles. They also had faux suede (looks like a sanded brown paper bag, and feels great) and a slick white "make your own whiteboard". I used the whiteboard cover on my cubicle's bookshelf covers for an instant whiteboard.
Here's the info from the label:
Kittrich Magic Cover Faux Metal Stainless
The closest I could find was
http://www.kittrich.com/MC/Regular/adhesive_woods.htm
Looks like Kittrich owns the Contact brand, but this product is discontinued.
Feb 18, 2008. 6:32 AMFrank in Virginia says:
Nice job on the Instructable! I like the flexibility of your buffing and brushing techniques; if you don't like the look, keep on going. Thanks for posting. BTW have you tried your techniques on plastic boxes?
Feb 17, 2008. 3:22 PMTheScientist says:
do you need to clearcoat to help protect the surface? or is it good enough as-is?
Feb 15, 2008. 9:03 PMOhm says:
That is just an awesome idea, I might have to disassemble a few of my pedals and refinish them, I think my Phase 45 clone would look good in the green, don't know way but I have always imagined it to be green? Thanks for sharing the technique.
Feb 15, 2008. 11:16 AMGeordiepom says:
What a great idea. So far I've only managed to find tiny quantities of transparent paint from air-brush suppliers. If any fellow Aussies know where I can get something similar to the stuff used here, please let me know.
Feb 15, 2008. 6:37 PMrichms says:
Same if anyone knows where to get something similar in NZ too thanks. I was going to paint my nixie clock base matte black, but this is a much much better option.
Feb 15, 2008. 3:21 PMdarkmuskrat says:
Lol, i was looking at how i could make a wood box look metal but this kicks ass too. definably +1
Feb 15, 2008. 1:52 PMrazor1000 says:
Where'd you get the box itself? Is it hand-made or can you purchase them somewhere? I'm working on a project that needs a nice box and I don't want to put into a crappy plastic radio shack box.
Feb 15, 2008. 2:37 PMconceptualstratagem says:
Thanks for sharing this, it will definitely help tinkerers give their projects a finished quality. Great first instructable +faved
Feb 15, 2008. 2:36 PMJohn Smith says:
Simply AWESOME. A+. Favorited.
Feb 15, 2008. 12:16 PMits a lion says:
This is great. I love the flamed and quilted look of the last two pictures. What type of pedal is it?
Feb 15, 2008. 12:09 PMmatseng says:
Looks great. I'll see if I can find the Krylon-X paints here also.
Feb 15, 2008. 11:15 AMmrmath says:
So the grain patter is the buffed part, and the wood color is just two coats of "transparent" paint. Amzaing. In the pictures on this page I would have sworn it was wood.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:amz-fx
See my web site for free info on how to build your own guitar effects pedals!
