Rainbow Loom Single Braclets
Published
Introduction: Rainbow Loom Single Braclets
You first need your temple. If have any comments comment below.
Step 1: Hook
Then u need your hook. To pick up the rubber bands
Step 2: Rubber Bands
Pick out any colors. Maximum 25 rubber band. Can use as many different color.
Step 3: Starting the Loom
Take the first two colors and place them how I did in the photo. Make a V shape on the template. Make sure the arrow is going up.
Step 4: Continue
Repeat step 3 across the whole template.
Step 5: Continue
Turn the template so it facing you.
Step 6: Continue
Use the hook to take the bottom rubber band and move to the next hook.
Step 7: Continue
Keep doing as said on step 6. Till the end of the Template. This is what it looks like when all colors are on the template.
Step 8: Finish Step
When done u add a "C" clip or "S" clip. To the big part at the end. As seen in picture number 2. With the red lining.Then start piling it off the board. When done with that you can hook ten other end to the "C or S" clip.
Step 9: ALL DONE!!
Now you single rainbow loom is all done!! Enjoy have any question please comment!
    • Stick It! Contest
      Stick It! Contest
    • Pets Challenge
      Pets Challenge
    8 Comments
    I need more rubber band any sugestions?
    A more descriptive title would be recommended. I had to read the whole thing to figure out what this was all about, while that is not a bad thing it would just be recommended.
    Ya you can use it by hand and you also can do other design on that template
    Is that plastic band holder designed for this purpose specifically? Or was it repurposed. Nice colors, and could you also do this by hand?
    If want me to change anything or have any question on something comment.
