3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Single LED Flashlight on 9 volt !!
This I'ble shows how to make a single LED flashlight from a 9v battery, that LASTS MORE THAN 200 HOURS !!! Unlike normal ones which last between 5 to 10 hours.
Step 1Components Needed:
Components Needed:
1) 9v battery
2) 9v clip
3) 2k ohm 1/4 watt resistor (even higher wattage would do, like 1/2 watt, which has slightly thicker wires)
Important Note:
Increase resistance to higher value, say 6.7k ohm or 10k ohm, if you are using lower rating led otherwise the led would burn out
or,
decrease it to 1k, if you have a worn out battery.
4) Insulation Tape
5) LED - colour of ur choice
6 comments
Jan 30, 2008. 4:15 PMSlim49 says:
Dude,
this ROCKS!
i will def make some.
Mr Steve
Jan 23, 2012. 3:54 PMSlim49 says:
made it today!
Drilled 4 Green LEDs into a bent L-shaped plastic. 2x taped battery & added a switch.
Beautiful.
Mr. Steve
Jul 6, 2011. 10:04 AMvishalapr says:
Really cool!!!
Jul 6, 2011. 11:17 AMvishalapr says:
Its brilliant!Ill comment and rate it right now!!!
Have a look at my ibles!!!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:pandyaketan
"May the good belong to all the people in the world. May the rulers go by the path of justice. May the best of men and their source always prove to be a blessing. May all the world rejoice...
more »
