Single Person Mosquito Net
Introduction: Single Person Mosquito Net
This mosquito shelter is made from a couple fiber glass rods, rope, and aluminum tubing. I bought 4 yards of mosquito mesh at Hancock Fabrics for about $20.00. It's an easy project and very simple to set up. No sewing required!
Step 1: Fiber Glass Rod Protective Covering
Fiber glass rod is strong and flexible which is a must for this project. Problem is, you get invisible splinters from handing it. To fix that I gutted 3/8" rope and used the sheath to cover the rod. Next I sealed them in by crimping and melting the ends. Even better, they now fit snug into the tubes they'll go in.
Step 2: Tent Pole Connectors
I got this aluminum tubing at Home Depot. I cut 4, 4" sections with a pipe cutter. Next I removed the burs with a file and drilled out a hole 10mm from the bottom edge.
Step 3: Form Eyelets in the Stakes
I placed the hooked end of a stake in a vise and closed it along with a socket. This created the needed loop for the connectors. After slipping the hook on, I closed it the rest of the way. The tube should fold freely for storage.
Step 4: Rope Rings
The ends of the shelter are gathered together and threaded through these rope rings. To make them I cut two 6" sections and fused the ends together with a torch. Make sure the stake is included in the loop.
Step 5: Cut the Net to Length
I figured out the length by rounding my height up to the nearest foot and doubling it. This net is 12' long. So about 3' will hang over the supports on each side. Nothing fancy about cutting. Just a pair of scissors.
Step 6: Set It Up
Hammer in the stakes as far apart as you are tall. Make sure they are close enough to form an arch with the fiber glass rods. Gather the ends of the net together and thread them through the rope rings. Anchor the ring stakes into the ground. Drape the net over and pull it tight. I used a constrictor knot and a fish bone to get the tension right.
    • Trash to Treasure
      Trash to Treasure
    • Pro Tips Challenge
      Pro Tips Challenge
    • Science of Cooking
      Science of Cooking
    What is the weight of this? I'm looking at bug-net options.
    Great build some folks with bed bugs might want to protect themselves from the pest by using this net. They also could build bed bug traps that produce CO2 give the little bastards a place to die rather than provide them with a meal to make more bugs.
    We never had them but you can get them from a movie theatre, health club, any store where the bugs are brought in by people or pets. It does not mean you are unclean if you get them it just means that yo ugot them now you need to get rid of them.
    Nice project but skeeters and other nasties live in the grass, so a bottom tarp is preferred. nice job!
    I LOVE it!!!! You're very creative & practical!
    wow, fabulous idea, execution and photos/instruction. For me in FL, the fire ants would be thrilled to have me all to themselves so I definitely would need a ground cover. Thanx
    Lt Greg, I think he did a great job and the project is plenty neat and clean. If you prefer the Hennesey than stick with that. I like this one as is cause it requires little skill and looks very "finished".
    very good idea
    The end result looks really good (and I like the red color you used).
    I wonder what kind of stores sell fiberglass poles? I'm in provincial Thailand, might be not easy to find that (as well as the net fabric)...
    very very nice. I love how you covered those plastic stakes with the nylon rope jacketing
