Single Servo Robotic Gripper
13,194
68
7
Published
Introduction: Single Servo Robotic Gripper
About: My name is Zach Sousa and I'm a Canadian highschool student that has a passion for making.
In this instructable I will show you step by step how to make a robotic gripper. You may be wondering: What does it do? It is basically a robotic hand that slowly closes and if something touches the switch while it is closing it stops so it grips onto the object that presses the switch.
This instructable was originally going to be a celebration instructable for achieving 50 000 views overall 50 followers and 25 instructables but now I am almost at 75 000 views! Thank you everyone that is following me and everyone that views my instructables!
Update: Adafruit has posted this instructable in their blog: http://www.adafruit.com/blog/2014/10/10/build-a-si...
If you like this instructable then you should check out this one: https://www.instructables.com/id/DIY-Head-Mounted-D...
Step 1: Parts and Tools
Here are the parts and tools you will need to make this project:
Parts:
Normally closed/ Normally open limit switch
Micro servo
Arduino
Wire
USB A to B cable
Tools:
3d printer
Filament any colour PLA or ABS
Computer with Arduino IDE
Step 2: 3d Print Files
3d print this file:
http://www.thingiverse.com/thing:482088
Any colour will do but I chose black PLA.
Step 3: Assemble
First glue the servo onto the base piece. Then Assemble the parts together by gluing one of the "fingers" to the base piece as shown in the first image. Then slip the second "finger" onto the servo horn as shown in the second image.
Step 4: Wire Servo
Wire the servo's negative wire (brown) to the arduino's ground. Then wire the poitive wire (red) to the arduino's 5v pin.
Step 5: Mount Limit Switch
Glue the limit switch to the "finger" that is mounted to the base and not the servo. Make sure that when the grippers are together the switch is clicked. Wire the servo's data wire between the switch so that the limit switch so it is normally closed. Then wire the other pin of the switch to pin 9.
Step 6: Upload Code
Upload the code to the arduino.
Step 7: Test
Test and see if it works. The gripper should open and close slowly. If it does place something into the gripper like a pencil and it should stay put. If you take out the pencil it should continue to open and close.
Please vote for this instructable into the contests, favourite and comment!
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    7 Comments
    Does the brand of servo matter ?
    Wow this looks great! I will hopefully try it soon.
    Hello! I like your design. Can you give me a link to the limit switch you used? I am interested in building one, but I can't figure out what to buy. Googling "Normally closed/ Normally open limit switch" doesn't seem to help and your photo is a bit fuzzy! Thanks so very much!
    Hello, You can use a switch like this one from radioshack:
    http://www.radioshack.com/spdt-switch-without-roller/2750016.html#.VMPo5Cl2fqB
    If you can't buy this one you can just Google "limit switch"
    Hope this helps!
