3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Single Wheeled Bike Trailer
I wanted to recycle an old foldaway bike I used for an earlier recumbent project to make a one wheeled trailer. I was inspired by an earlier instructable but didn't want to do any welding, just nuts and bolts. I'm a big fan of 1/2" conduit for lots of metal projects. This project took about 2 weeks off and on. I'm going to use it when I bike around town or to the beach for the day and carry lunch, drinks, boom box, etc. It's not meant for heavy loads. That's another project for another time.
Step 1Modifying The Frame
Modifying The Frame
Here's a shot of the under side. I cut the existing frame and modified the vertical angle of the handlebar collar to be perpendicular with the ground so it wouldn't jam up when it pivoted. Geometry is critical here.I had to used plate steel and bolts to join the frame because of no welder. I reinforced the 1/2" plywood top with sections of 1/2" conduit that where flattened and bent in my bench vise. They were secured to the frame with sheet metal screws and eye bolts. I used cap nuts to finish the connections off to look right.
17 comments
Sep 5, 2011. 7:03 AMyyinfo says:
Thanks,I like it,have fun !
Jan 22, 2011. 7:13 AMBillBiker says:
I have been looking at similar projects I must say this one should have received some sort of recycling or green award. VERY NICE JOB!
Jan 30, 2011. 12:20 PMBillBiker says:
Done :)
Oct 6, 2010. 2:19 PMTSC says:
Nice job man!
Jul 29, 2010. 2:31 PMzack247 says:
im looking at the hitch, and i like it! i see that the hitch is a ballbearing from the front fork of the bike. i think i'll do something like this, but with 2 wheels
Mar 15, 2010. 12:22 PMeagleapex says:
 Using the screw eyes as structure is brilliant. Elegant design.
Mar 15, 2010. 12:20 PMeagleapex says:
 Real quality build here. Great job!
Jun 5, 2009. 1:44 PMjamar3030 says:
It looks like you used a head tube (instead of steel plumbing pipe) from a bicycle here as your horizontal pivot and welded it to the trailer. Is the steel pipe inside the head tube?
Jul 19, 2009. 6:29 AMrangeside says:
yeah it does look like a headtube
Sep 27, 2009. 10:50 PMpteranosaur says:
...it is...but it's vertical,not horiz...
Sep 2, 2009. 6:39 AManyoldmouse says:
Do you have some kind of conduit squishing tool? I see the kink in the rail going to the hitch, so I know that you didn't use a bender for that part, but you have this getting down to a flat piece of metal (very clean) wherever you put in a bolt. I haven't worked with conduit before, so I don't know. Do you put it in a vise?
Sep 9, 2009. 8:43 AManyoldmouse says:
How did you flatten the ends? I'm imagining a vise and a cheater bar for more leverage or that you have access to a press.
Apr 8, 2009. 8:01 PMbosmith says:
Cool. Nice hitch.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
44
Author:graphicsman(The Toolman Site)
a.k.a. "The Toolman" has been creative and worked with his hands all of his life. He has been employed in a wide variety of industries including a museum, a major power tool manufacturer, a national v...
more »
