3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Single Wheeled Bike Trailer
Step 11DONE! (and lessons learned)
Alright, there you have it...a working trailer!
To test it out, I took the two pavers (40 lbs) on the trail for a 15 minute spin. The trail is unpaved that consists of mulch, crushed rock, washout and hardpack dirt. It was the perfect test for what I'd be experiencing on the C&O Canal towpath. After returning home, I inspected the brazed joints and they seemed to have held up well.
Of course, the real test was day one of the trip. When we pulled into the campsite that first night, I inspected everything and it all looked good. The only problem I encountered on the trail was when the wheel guard bent a little (I still haven't determined exactly how that happened) and started rubbing against the tire. I bent it foward a little bit and that fixed it for the duration of the trip.
The only thing that wasn't done prior to the trip (and still has yet to be done) is paint it. I've decided on painting it yellow and am toying with the idea of adding a cut out of flames for the sidewalls. That would be cool.
Things I would do differently next time:
1. Make sure the fork is straight so the wheel is perpendicular to the ground.
2. Decrease the length of the trailer. Sure, it worked for our trip, but it also allowed us to bring more because the space was there. (I'm not sure how much the gear we took with us weighed, but it was far more than the 40 lbs. the pavers weighed!) It would also (probably) make it easier to handle, especially when going down hills.
3. Adding a way to stand the trailer upright (without having to lean it against something) would be beneficial.
4. While the way I secured it to the bike worked, it wasn't easy to get on and off. I would come up with a quick-release mechanism so that it could switch from one bike to another w/o having to unload the trailer and take the wheel off. (In order to take the screws out of the braze-on, the rear wheel of the bike needed to be moved forward so that the screw wouldn't hit the cogs of the cassette.)
5. When I was stripping the bike, I tossed the sets of bearings in the head tube. I should have kept them as they would've helped decrease the stress at the pivot point by allowing the head tube to move around the seat post in a smoother manner. I'm not sure if it mattered, but it's something to think about in the future.
So....there you have it: a single wheel bike trailer. I hope you enjoy making one as much as I did!
10 comments
Mar 2, 2011. 2:17 AMddarkeststar says:
I'm inspired.
Knowing that you have a similar kind of skill base as I do regarding brazing and the like and then seeing the result of your efforts I feel very confident that I could recreate this excellent design.
Thanks a lot for posting.
Aug 13, 2009. 5:18 PMjefferywelch says:
First off have to say thank you for posting this trailer it is great and works. I just finished my trailer this afternoon and I took it for a 7 mile ride with 25 lbs of gear on it for the maiden run and it was on/off road and it held up great. I made a few design changes from the original and have included a few pictures to help. First I did not use a front fork for the rear tire assembly I just bent the conduit to form the rear end. I flattened the ends of the conduit and drilled a 3/8 inch hole to install the 16" tire. The front assemble was the front forks from a little princes bike which is where I also go the tire from. I included the whole neck assemble so that was the bracket to hold the top rail in place and this way could also use the original bearings to keep a very tight and smooth operating system to connect the trailer to the bike. As you can see I used a few braces for the bed of the trailer. The conduit cost $1.65 at home depot and all together the supplies cost a total of 25 dollars. I did go to Craig’s list and get the little princes bike for 7 dollars and a free mountain bike from the local bike store that was being scraped. I really love this trailer and find it very easy to tow and hardly realize it is behind me. Thanks again and hope this helps.
Sep 29, 2009. 9:44 PMstudes4ever says:
Hey there. I really like what you have done with this trailer. I am preparing to build one based on this design. Can you send me any pictures of how you attached the trailer to the bike. I think I have come up with a plan that is both simple and elegant, but I would like to see what you did too.
Sep 30, 2009. 11:54 AMjefferywelch says:
Sorry for the long wait on pics been out of town will get to it this weekend and post some more details. So far it is a great trailer and have used it with 50 lbs on it and everything is going great.
Jul 26, 2009. 7:18 AMcclev1967 says:
awesome build, this is exactly the type of trailer i want to build. even unpainted it looks great. thanks for sharing, if it didnt fall apart with all you had packed on it, then id have to say you did something right, im going to start building mine today. and i want to eventually incorporate a way for it to haul a kayak on it. agian thanks for the great info on your trailer.
Aug 7, 2009. 10:31 PMcdltpx says:
I wish to build a trailer too but I want to build for one task the collection of AL cans to transport to point of sale. A dual frame that is collapseable so when trailer is empty is will have a low drag. Have the system to fit the bags to make transfer at POS a breeze. Not everyone wants to be involved in this but rather than go to a gym to loose my 100 lbs I wish to do something that will pay me back with $ something that has more than one objective. I use to like to ride my bike but as a trucker the pounds have accumulated over the years I want this to change with in a year. I like your design it works well all you need to do is rig dual kick stands so you can stop your bike on the plains. Went to a police auction and bought so much bike crap it needs to be fashioned to other things. I have quite a few bikes that are ready roll they need to get cable replaced and the usual adjustments but it would not kill me to augment one for this task. I could have my good MB and factory AL trailer for grocery trips and the other home made and yackydy bike for industrial use. Great for fishing too who wants to get their food grade trailer nasty.
Apr 20, 2009. 4:06 AMjpvskv says:
Great Instructable! A fix for the rear wheel guard would be to braze two supports between the guard and each of the forks.
An alternative for the connection to the bike would be to go up and over the rear bike wheel up to the seat post as seen on the Atomic Zombie site here: http://www.atomiczombie.com/product-cyclebully.htm You could also do a U joint from the seat post from a block of metal.
One last suggestion: Use a 2x6 the width of the trailer and stood on end for support of the trailer/bike so you don't have to lean it up against anything at all.
Jun 11, 2009. 7:30 AMUC FATHER TIME says:
You could make a sort of frame stand like a motor cycle.Put it near the trailer wheel and use a cable to actuate it,just stop reach down grab a handle pull to contact the frame stand to the ground and push the bike back. And an extention spring holds it up when not in use.
Apr 19, 2009. 6:53 PMgemquest says:
Great instructions and pictures! I was thinking maybe the connection bar from a baby tow trailer might work?
Apr 3, 2009. 8:51 AMrangeside says:
Nice build. I'm looking at doing almost exactly what you've done here, keeping your building changes in mind (ie thing i would do differently next time) I'm wondering how its holding up lately? The design and support point seem to take all the directional stresses and forces into account (I'm no engineer myself) But sometimes time takes advantage and points out structural flaws. Your instructions were really good. Thanks for taking the time to share with everyone! I'm planning to do the same, but maybe on the second build after I figure out if and where it might break. Any other suggestions would be great, Again much appreciated for the share of experience and knowledge with this build. Happy trailing
Apr 13, 2009. 2:48 PMyanggers says:
great creation and great 'structable! The whole thing looks fun to build and looks strong like a tank. One suggestion, really just something to keep in mind for projects to come, is to use triangular geometry (like the bike frame itself!) on stress points.
Apr 15, 2009. 9:52 AMrangeside says:
I was thinking of incorporating triangular geometry on the frame where ever possible. I'm not familiar enough with that to know the specifics of that subject though. Thinking back to school, I remember that there are some key "rules" to triangular geometry make it work as it should. Any suggestion as far as how this frame might be improved through geometry would be welcome! cheers
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
15
Author:samfelis
