3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Single Wheeled Bike Trailer
Step 2Remove Unwanted Bike Parts
The first thing I did was strip the old frame of parts that I needed for the trailer. I got an old mountain bike from a local freecycle member and immediately stripped off (and saved) everything I didn't need.
Once the bike was stripped of unwanted items, I took the hacksaw out and started cutting off the rear triangle. I wasn't sure how long I needed the "arms" to be, so I cut as close to the seat tube as possible.
Using the conduit bender, I bent the bottom arms of the rear triangle so that they were parallel to the top arms of the triangle. See the second picture for a look at what I mean.
I also cut off the head tube from the frame for use in the pivot point assembly.
I then ground off the residual metal from the head tube and tapered the rear arms so that they fit together nicely and provided a larger surface area for brazing. (I didn't braze this together at this point, although it could be done here.)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
15
Author:samfelis
