Step 6Attaching the Wheel to the Trailer
At first I decided I would drill a pair of holes in the fork stem and put two fork supports through the hole. I would then braze the fork supports to both the fork and the trailer. After further consideration, however, I figured three supports was better than two, so that's how I ended up with three sets of holes.
Once the holes were drilled in the fork, I slid the supports through the holes. Before brazing the fork supports onto the frame, I cut the conduit connectors in half and, after filing down the inside so they'd fit, slid them on the supports so one was on each side of the fork. I straightened out the fork (as best I could) and tightened each connector so that (in theory) the fork would remain straight and true with the rest of the trailer.
The fork assembly was now ready to be attached to the rest of the trailer, which was simply a case of brazing each support onto the bottom frame in the desired location. Once the fork assembly was in place, I adjusted the fork again so that the wheel would be perpendicular to the trailer (again, in theory) and then brazed the connectors to the supports. The last step in this process was brazing the fork to the supports. (As it turned out, the wheel wasn't completely perpendicular to the trailer...I guess I only measured once vs. twice.)
NOTE: You should properly prepare surfaces being brazed by cleaning them and removing any paint with a wire brush, a wire brush drill bit or wire wheel (on the bench grinder). This will not only allow the brazing material to adhere better to the metal, it will not release paint toxins into the air.
comment
Add Comment
samfelis (author)
says:
Add Comment
