3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Single plant Hydroponics (easy)
Hydroponics is simply growing plants in water. Most are large bulky machines that can have 10 or 15 plants on it and it will take up a large amount of room. For some of us we need a single plant hydroponic system. This is that and can be made with simple household items. I will show how to do this
Step 1Materials
materials
-small aquarium pump
-thin aquarium tubing 2-3 feet
-tennis ball can
-plant
-broken screen door or anything of the like
-gravel
-a plant
Tools
-scissors
-hot glue gun
-shovel
-Optional soldering iron
21 comments
Mar 17, 2010. 10:54 PMhotchilidog7 says:
 Do you fill the container all the way to the top with water?
Nov 23, 2011. 7:57 AMknexfreak32 says:
No you would probably want the water level 1 in. below the top.
Nov 15, 2010. 7:35 AMahmad2117 says:
so i use gravel instead of soil?
Mar 15, 2010. 12:34 AMaznaquarist169 says:
man your doing this the hard way! simply do the version with the water bottle cut in half!
Jan 22, 2010. 9:53 AMradioman_cut says:
silicone should work also
Dec 25, 2009. 4:34 PMKaber says:
A 1 or 2 Liter soda bottle would work, too, wouldn't it?
Aug 11, 2009. 11:04 AMsquidstew says:
I was trying to figure out where I could get a piece of screen like that, and suddenly I thought "Why not an old sock?" Everyone has a couple of old socks, probably a few mismatched ones. It's already about the right shape (more so with tube sock I guess), so you just drop the toe end down in the container, and stretch the elastic over the top,(probably glue it in place so the weight doesn't pull it down) fill with your medium and plant.
Jul 13, 2009. 5:39 PMmacrumpton says:
You don't have to make a hole in the tennis tube, you can just run the air tube up and over the edge and down into the water. A little tape will hold it easily and you have no leak worries.
Jun 12, 2009. 9:04 AMfamousguy13 says:
i was wondering if the hot glue actually created a water tight seal or if leaks eventually occured? if it holds water for a signifigant amount of time, kudos. lots of pics were nice.
Jun 12, 2009. 9:50 AMPainkilla05 says:
This is pretty cool and a def add to my To Do list.
Jun 6, 2009. 5:28 PMkarossii says:
I like your instructable, but... not to be pedantic, but you would be well served to go over the instructable for spelling mistakes. Here is a before/after snapshot of just step 2;
BEFORE: OK so to start you take the tennis ball can and take the wrapper off. After that you clean it out and with the soldering iron burn a whole one the side about and inch from the bottom. You want a six inc T You then insert a piece of the piping in and glue i shut. Having a tight seal is essential if you and bad things will happen
AFTER: Okay, to start you take the tennis ball can and take the wrapper off. After that you clean it out, and with the soldering iron burn a (hole) (on) the side about (an) inch from the bottom. You want a six (inch) T. You then insert a piece of the piping in and glue (it) shut. Having a tight seal is essential if you... (and bad things will happen. - seems like something is missing there).
Jun 8, 2009. 1:43 AMkarossii says:
This is the first time I have made a civil comment on spelling/grammar... and someone actually fixed things instead of griping about my constructive criticism. I just wanted to add a huge 'Thanks' to the author for fixing the problems, as well as my initial appreciation of the instructable itself. Well Done!
Jun 8, 2009. 1:30 AMawang8 says:
I think the missing word is don't.
Jun 7, 2009. 11:56 PMlemonie says:
It looks like something has spell-corrected this, but picked the wrong words. The "bad things" is an editing oversight.
Yes, it's worthwhile reading the whole thing once it's published, correcting it, reading it again, and repeating until it's right.
L
Jun 8, 2009. 1:31 AMawang8 says:
Oh yeah, I'm so doing this to grow tomatoes.
=P
Jun 6, 2009. 10:08 AMlemonie says:
Looks super simple. Do you add anything to the water? L
Jun 6, 2009. 10:34 AMTool Using Animal says:
You need a check valve.
Jun 6, 2009. 10:04 AMChrysN says:
Cool, this is nice for small spaces.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:stramposch
