Introduction: Single Rubber Band Bracelet
This is the first bracelet you ever make using the rainbow loom. It is a beginner level and it takes at least 1 or 2 minutes to make. You will need a loom (works with Rainbow loom, Wonder loom, Fun loom, or any other brands), rubber bands, a hook, and 1 C-clip.
Step 1: Placing the Bands.
Put one rubber band on the first pin. Then, drag one end of it to the second pin next to the row you're using. Then, grab another one and drag one end to diagonally. Continue to do this until you reach the top.
Step 2: Looping the Bands
Turn your loom over so that the pins are facing you. Grab your hook. DON'T LOOP THE FIRST BAND. Then, grab the second band and place it on the third one. Continue to do this until you reach the top.
Step 3: Taking It Off the Loom
Grab 1 C-clip and place it on the band you just looped. Then gently take it off the loom. Grab the end and place it on the C-clip.
Step 4: You're Done!
You now have a single band bracelet that you can wear. Congratulations on making your first rubber band bracelet!
