loading
Its a single shot gun
Ammo: red rods
It started as a mod of killerk's gun
When I was trying to make a new frame for the mechanism so I could make it more powerful
Step 1: Barrel and Slide
Picture 1 - 5: barrel
Picture 6: slide
Picture 7: combine barrel and slide
Step 2: Trigger
Picture 1: part 1
Picture 2: part 2
Picture 3: combine part 1 and 2
Step 3: Handle
Picture 1 - 2: part 1 and 2
Picture 3 - 4: part 3 and 4
Picture 5: part 5
Picture 6: combine part 3 and 5
Picture 7: combine part 3 and 4
Picture 8: combine part 3 and 2
Picture 9: combine part 3 and 1
Picture 10: combine part 3 and trigger
Picture 11: attach a rubber band
Step 4: Ram
Ram with tape and straps
Step 5: Frame of the Slide
Picture 1: part 1 and 2
Picture 2 - 4: part 3
Picture 5 - 6: part 4
Picture 8 - 9: add part 1
Picture 10 - 11: add part 2
Picture 12: add slide
Picture 13: add handle
Picture 14: add firing pin
Picture 15 - 16: add rubber bands
Picture 17 - 18: add rubber band
Step 6: New Handle
New handle that can hold more power.
!!! You need to break a grey connector to make this. (displayed in picture 2)
it looks phat.... could u make it a semi auto
I HAVE JUST FOUND SOMETHING WONDRFUL OUT! WHEN THE KNEX COMPANY STARTED OUT THEY MADE THE TAN LOCKS AS RECTANGLES INSTED OF HAVING ROUND TOPS. I HAPPEN TO HAVE SOME OF THE OLD TAN LOCKS THAT STILL HAVE THE FLAT HEAD, THE HEAD IS JUST AS HIGH AS THE BOTTEM OF THE HOLE IN THE GREY CONNECTORS! THIS MEANS NO MORE BROKEN GREY CONNECTORS!! YAY!!1 I WILL TAKE PIC SOMETIME TODAY.
i know it is old but it came out orange and connected two sides
i want to see
lol i have a ton of those along with 1 green 4 slot connector that was accedntly made yellow... this means i have a yellow green connector itt just pretty cool
? did you spray paint it?
I tried spray-painting knex, the paint just rolled right off.
no.... its a missprint.
lol.
i don't think it's a misprint...i've got tons of those.
unless you have a picture thats impossible cause i know its a misprint
ok, tell me how to post a picture and i will. (i'm bad with technology)
easiest way i think is to host them on imageshack.us then copy the link to here.
here you are. are these what your talking about?
yep thats it... but they have to be misprints.... dont they
ya, but i have like ten more not in the picture.... that's a lot of missprints.
wait, i think i found out...give me a while and i can get it up today hopefully. i've got a busy day though
IS IT STILL COMING?
I GUESS NOT
MMMHMMM
THATS RIGHT
I LIKE TO YELL AT MICE WITH MY SHIRT OFF!!<br/><br/>AAAAAAAAHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH!!!!!!!!!!!!<br/><br/>I STEAL PEOPLE'S SCABS!!!<br/><br/>*RIP* HOO-AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHHHHHHHHHHHHHHH!!!!!!!!!!!!!!!!!<br/><br/>
i thougt you were 22 years old :-?
LOL
LOL BUSTED
i had couple of those locks too!! i was wondering about them...
they are square on Mclad aren't they, i don't have the programme, i just saw a couple of rectangular tan locks
yea, they are.
this is a cool gun, but the firing pin often breaks when i pull it back, because the rubber bands pull the orange connector down, and the tape and straps aren't enough to keep it strong.
I now You need to balance the rubber bands They should make iron knex :)
just iron rods, then the firing pins would be able to hold so much tension, but i can only pull this with lower than 6 #64 bands on it, so we would have to put the bands on after, and iron ammo so it goes really far.
if they made iron knex, knex guns would be iron heavy try aluminium
lol yes and the pieces would also be so much harder to click in cause it bends less, they would be very powerful though<sup></sup><br/>
if they made iron knex then they woudl not work. the connectors plastic needs t bend to connecto to things. good luck trying to make iron bend. maybe aluminum would work, or tin.
i also thought of metal knex. for firing pins. cos my ones always bend even if balanced, u move it slightly and the whole thing bends, now you have a fucked up grey rod.lol
I also want metal k'nex!
One day I will make metal k'nex. The guns would be so powerful, and pritty heavy.
if it was made of metal, than the knex guns would even have an authentic weight and feel!
its impossible I tried when you make them into metal they cant click together
ok? i know that now it wont click together, but where did you get metal knex? no offense but i 100% dont believe you.
i made it in my forge
i tried it with a bluetack mold of a blue rod, and i pured it in, it looked okay, but the same thing happened, it doesn't click it, except i used solderwire and melted in a spoon over my gas cooker &lt;sup&gt;=3&lt;/sup&gt; it worked atleast as metal knex, but it was all dodged up at the rims =/&lt;br/&gt;<br/>
I used a concrete mold and used aluminum as the metal but as you said it doesn't click so i molded a grey rod with a orange connector <sup>for a ram</sup> which worked good<br/>
yeah, that would work well, but the only problem is, i'm 13, and don't get any money lol, i'm not poor, i just don't have pocket money, and iunno where to get concrete from or how i could melt aluminium safely without getting burn't lol
make the forge on my fav list
i can't, no offence, i'm english, so quickcrete means nothing, and i have no powertools that i have access to
? a forge?
yup heres how to make it <a href="https://www.instructables.com/id/Ultimate-Guide-to-Making-a-Cheap-but-Effective-Alu/">https://www.instructables.com/id/Ultimate-Guide-to-Making-a-Cheap-but-Effective-Alu/</a><br/>
yea. the bending of the plastic is what make the rod be able to connect. if you watched a connectiong of a rod to a connector in slow motion, you would see the tabs on the connector bend out and then in again to hold the rod. metal doesent bend.
well its kind hard to balance them for how it breaks, because it breaks downwards when I pull it up to put it on the yellow rod. Nothing actually breaks, but the orange connector just shoots of the rod.
About This Instructable
5,251views
7favorites
License:
More by ipod killer:Shotgun Single shot handgun Knex Sniper Rifle
Add instructable to:
