Six Panel Display Setup
Published
Introduction: Six Panel Display Setup
Here are the instructions for setting up the Six Panel Display.
Step 1: Open the Box and Identify the Parts
There will be eleven (11) parts inside the box:
2 Frames
2 Top Wire Hook Assemblies (Short)
2 Top Wire Hook Assemblies (Long)
2 Bottom Wire Hook Assemblies (Short)
2 Bottom Wire Hook Assemblies (Long)
1 Wire Grid
Step 2: Insert the Two (2) Top Wire Hook Assemblies (Long) Into Each Frame
Make sure the hooks are facing up. It is easier to complete this step with the frame on the ground, as shown in the photo below.
Step 3: Insert the Two (2) Top Wire Hook Assemblies (Short) Into Each Frame
Step 4: This Is What the Display Should Look Like With All Four Top Wire Hook Assemblies Attached
Step 5: Insert Each of the Two (2) Bottom Wire Hook Assemblies (Long) Into the Bottom of the Frame
Step 6: Insert the Two (2) Bottom Wire Hook Assemblies (Short) Into the Bottom of the Frame
Step 7: These Pictures Show the Slots on the Frame That Will Be Used on the Lower Wire Hook Assembly
Step 8: Attach the Wire Grid to the Top of the Frame
Step 9: Mount the Cartons to Each Side of the Six Panel Display
Step 10: Here Are Views of the Cartons From Inside the Display
Step 11: The Finished Six Panel Display Is Pictured
Next, add the seed and carefully roll the rack to its pre-selected location.
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    • Oil Contest
      Oil Contest
