Six Petal Flower Pendant by Mrballeng
I made this flower from 3 nickels, a bullet shell, and a hot set crystal. I wasn’t sure if it was going to turn out so unfortunately I didn’t take photos along the way.
To make it I started out by cutting 3 nickels in half and rough shaping six petals. I soldered the petals in a stack and filed them to the same shape. I then de-soldered the stack, used a paper clip to emboss, and filed the edges round.
I cut the Primer side off a bullet shell and then filed it round. I soldered it all together to include a metal circle on the back for reinforcement. I used a heat gun to set the crystal. After polishing I made a jump ring from a paper clip.
(Use an expended cartridge. That means a shell that has already been shot. Do not under any circumstances use live ammo.)
Kryptonite says: Sep 11, 2011. 2:32 AM
Neat, what chain did you use?
Mrballeng (author) says: Sep 13, 2011. 11:30 AM
This is a silver chain that came out of my wife's jewelry box.
Kryptonite says: Sep 14, 2011. 2:00 AM
Convenient! Looks really nice.
lastaztec says: Sep 10, 2011. 10:42 PM
what exactly do you do to hammer the nickle flat?
Mrballeng (author) says: Sep 11, 2011. 12:21 AM
I lay the nickel on a smooth steel surface and hit it with a smooth faced hammer. You can see all my fancy tools (not really that fancy) through out most of my other instructables.
slyphoenix says: Sep 10, 2011. 10:18 AM
This came out good! It looks good on your wife...you should make one for mine!
Mrballeng (author) says: Sep 11, 2011. 12:19 AM
I'll trade you for a dinner plate of lasagna.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
