Introduction: Six Simple Ways to Fix the "Open Tray Error" for XBOX 360's
Click below for a video tutorial:
vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv
http://www.youtube.com/watch?v=Ed5x5TexYSQ
PLEASE READ THIS: Before reading this, make sure the problem is your xbox and not the disc simply by putting a different disc into your xbox 360.
If your like me, you obviously have and xbox 360 that has or has had the "open tray error". This error is when you have a disc in your xbox 360 and it doesn't "see" it and it displays the message "open tray" as if there isn't a disc in your xbox. There is also an error just like this but when you put a disc in the xbox makes two clicks. I call this error the "double click error".
Anyway, in this instructable I will teach you six simple ways to fix these error that I have tried, and every one of them has worked for me at least once.
Not all of these will work at one time, and then work at another. So try them all, at least one of them will work. But if your in a hurry try Fix 5 (Step 5) for the open tray error and fix 6 (step 6) for the double click error because they have worked the best for me the most times.
Sorry about the pictures, they wouldn't really help so I didn't take them. But any way, let's get started
Step 1: Fix 1: Blow Some Air Into the Disc Drive
This is probably the simplest fix. But has worked for me.
What you'll want to do is open up your disc drive, (where the disc goes) and blow some air into the space that let's you see into the xbox itself. I think this sometimes works because dust or something gets on the laser that reads the disc, and by blowing some air into the space, you remove that dust.
Step 2: Fix 2: Blow Some Air Into the Power Cords/spaces
Fix 2: what you'll want to do for this is turn off your xbox, remove the power cord from the xbox and blow some air into the the part of the cord that goes into the xbox and then blow some air into the part of the xbox where the cord goes.
Step 3: Fix 3: Clean the Disc
Fix 3: This fix will try and make it easier for your XBOX to read a disc by making the disc easier to read. We do this by taking a disc out running some cool water over the disc and then gently drying it either by dabbing it or by rubbing the disc from the inside to the outside of the disc. Then just put the disc back into the xbox.
Step 4: Fix 4: Try Different Discs
Fix 4: This is and easy fix, just try putting different discs into your xbox. even try regular xbox games and DVDs. If your xbox reads one of them, then switch the disc to the original game you wanted to play.
Step 5: Fix 5: Keep Opening and Closing the Disc Drive
This fix is probably the best fix because it has worked the most times for me.
So all you'll want to do is put a disc in the disc drive, close it and wait for it to load. If it says "open tray", open and close the tray again. Now keep doing this. It should eventually load the disc. But keep trying for at least 5 minutes straight.
Step 6: Fix 6: Knock on the Xbox
This fix has worked for me with the "double click error" even though it it kind of wierd. I'm not sure it works with the "open tray error" but you might as well try it.
So what you'll want to do is first, open the tray and put a disc in. Then close the tray and start gently knocking on the xbox right above where the disc is inside the xbox. Now keep repeating this until it works. It could take a while, but it could not. You might want to try this to for like 5 minutes.
If your not sure how to do this step, look up a video on how to do it. It might help.
Step 7: Hope I Helped!!!
Okay guys, those are all the fixes I've done that have worked for me, and they should work for you too. But if they didn't, (and make sure they don't work by keep re-trying the steps, it might just save you some money.) you might want to start looking up tutorial on how to fix the error from the inside by taking the xbox apart and doing some things to the inside. But anyway, I hope I helped. Bye!
