The above linked instructable is awesome. It's cool, and the joints it uses (holes drilled in box tube) will egg out very quickly and degrade with time.
So, I decided to beef it up, so mine wouldn't end up crippled. I followed the instructable pretty well, but used different motor mount configuration, used the wheelchair's motor controller, and made my eccentric drive plate out of steel (free) instead of aluminum.
The theory in my telescoping sleeve bearings is that there is strong steel in the middle (bolt), and less strong steel on the outside (pipe/box tube), with brass and grease inbetween. This brass/grease will decrease wear on the steel components, and take up the slop.
This is a work in progress, to be updated as progress comes along.
Remove these ads by
Signing UpStep 1Measure your bolts.
Your top end bolts will probably be smaller, I used 3/8th up top, and 1/2 for main drive.
Did you use the standard diminesisons for your plans or did you modify them? To get the increasing the length of the legs makes the body waaaay to big for a standard sized garage.
That being that, I'm storing it until fall, when I will participate in a robot show, and most likely, one of justin grey's robots will destroy, then burn my robot.
Yeah, I wonder what's up with the sleeve bearings getting eaten up. The original hexabot maybe has about 10 hours of loaded operation on it, and it hasn't had any problems with things getting really worn out. There's more slop in the joints than when it was first built, but nothing too terrible. Only thing that immediately jumps to mind is an over-constraint problem. Maybe if the tube inserts in welded into the legs and linkages have some angular misalingment, combined with the tight fit of the brass sleeve, there could be excessive wear? Or maybe the brass sleeve is just too thin? This is a puzzling problem.
How much does this thing weigh?
