Skadeboard Rack Made From Skateboarddecks
Introduction: Skadeboard Rack Made From Skateboarddecks
I tried to find a good and cheap rack for my longboard, but at the end I made it myself. You only need 2 cheap skatedecks, or better you have some old ones. And with that, a saw and a few skrews you get a great rack for up to 4 boards.
(I decided to make some and sell them >>
Step 1: Parts
I bought 2 decks at amazon for about 20€, maybe you have some old ones at home or you can find some cheaper decks. Beside the decks I get some griptape, but I decided to not use it, because if I put it on the decks I will probably damage my longboard later. On amazon I could choose the witdh of the deck and I choosed the biggest with 8.75'', to have the maximum of space available for cutting.
Step 2: Slots
Now the cuts have to be made. My Longboard needed a cutwidth of 2.5 cm (0.98 inches), but that belongs a little to your own borad you want to use. But I think in this slot should fit nearly every Skate- or Snowboard.
The cuts itselfes are made in a distance of 15 cm (5.9 inches). If your board needs more space, you probably need a larger distance. But with that distance I can make 4 slots and that fits perfect to the possible available boards in my home sweet home.
Making the cuts is the hardest part. I used a jig saw for the straight lines and the ends are made with a drill and a lot of rasping and grinding. But I also get a little bit of help from my son.
Warning!!! I made little scratches on top of the deck with the jig saw, so watch out if that matters for you.
Step 3: Brackets
For the metal brackets I get some perfectly fitting to the holes of the deck. That made it really easy to attach them to the deck with simple 4 mm (0.15 inch) metal skrews. As an alternative you can order a skrewset for one deck in you skateshop to get the correct skrews.
Step 4: Mount It to the Wall
The brackets located the board in a little more than  a 90 degrees angle to the wall. So I used a hammer to correct the angle of the brackets a little bit.
To avoid that the longboard is hitting the wall and make it dirty, the second deck comes up. It is simply attached to the wall with skrews.
Step 5: Finished
Here you can see the final rack made for 4 boards.
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Science of Cooking
      Science of Cooking
    Ok thanks for the info
    Where did u find the wall brackets with the holes to match up with the skateboard holes?
    fortunately i found them in a local hardware store, but i live in germany so
    probably not easy to get for you. but it seemed like a standard size, at least here. but you can use basically every brackets, just drill holes in the right places. i also tried to find some brackets made out of wood, maybe you can get some. i think wood brackets would fit even better ;)
    thank god!! i cross in your account! :D
    Awesome job! Really clean and I like that idea that the skateboards are held up by more skateboards. I think it looks good holding up longboards but it might look a little weird with shorter ones. I have trick decks so I may try it with just the hangar part (ie. without the wall guard).
