Materials:
any number of decks
Twine
Tools:
Drill
Mitre saw
calculator
Remove these ads by
Signing UpStep 1Design
a=sin(theta/2)*2r
x=tan(theta/2)*8
b=a-2x
(see diagram)
Where theta is 360/number of pieces
If you're decks (or any kind of board) are not 8" wide, you can change the 8 in the formula for x to the desired width.
You have to keep in mind that you can only cut about 12 inches of the middle of the skateboard (within the wheelbase), after that the contour changes and pieces wont fit together uniformly when you put them together. You'll also run into the holes for the trucks.
So, if you're not using the spreadsheet and you want to do it by hand, you have to find out how many pieces you can get out of one skateboard. if you're using 1 piece the total width will be "a" if you're cutting 2 it will be "a+(b+x)" if you're cutting 3 it will be "a+2(b+x)". The pattern is L=a+(n-1)(b+x), where n is the number of pieces.
I wonder how tactile you could make that by using bungee cord instead...
