3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Skateboard with PIC microcontroller and LEDs
Step 5Build housings
Build housings
  • last photo ←
The LED housings are carved out of Balsa, reinforced with fiberglass and 60 minute epoxy then blended into the board using Bondo (plastic body filler). The housing for the circuit board is created using a project box from Radio Shack, cut to conform to the curves of the board then attached using epoxy and fiberglass. The project box is also blended to the board using Bondo. The LED mounts at the front and back are made out of Aluminum strips from Home Depot, that are drilled to accept the LEDs. The circuit board was constructed first so that the height of the project box could be determined, again using the TLAR method.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:fourball
