Skeleton Horse Halloween Display
3,266
58
8
Published
Introduction: Skeleton Horse Halloween Display
A static halloween display made out of PVC pipe, 3/4 trim board and spray foam.
Step 1: Skeleton Horse
After deciding on the size and pose of the horse, I cut all the flat pieces for the pelvis, shoulder blades and backbone out of PVC trim board.
Step 2:
I used various sizes of PVC pipe for all the leg pieces. Each bone was heated with a heat gun in order to bend and Shape them. The legs all have a PVC pipe in the center for stability with larger pipes placed on it. The ribs are PVC pipe cut length wise into four pieces.
Step 3:
The ends of each pipe was filled and shaped with PVC board and spray foam. Then the joins where wrapped with resin casting tape.
Step 4:
I carved the skull and vertebrae out of extruded styrofoam and glued them on a PVC pipe.
Step 5:
Then the whole thing was painted and the legs and ribs where screwed back on for the finished horse.
Halloween Decor Contest 2016
Third Prize in the
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    8 Comments
    Wow! Really creative use of materials. Looks great.
    Amazing! How much much did it cost to create the horse aside from your time? Great job for sure!
    I used a lot of old PVC pipe I already had but if I were to guess, I would say $65 to $75 dollars. The PVC trim board was the most expensive at around $35 followed by the foam and PVC pipe. The resin tape was purchased on clearance. The best part is I had enough left over to make the Zombie Wolf.
    Amazing job! This is so cool! :)
    Excellent work, thanks for sharing and welcome to Instructables :)
    This looks amazing! You did a great job :)
