3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Ski Bike
Ski Bike
This will show you one way to build yourself a Ski Bike (aka Snow Bike, Skibob, Skike, or Skicycle). It is a downhill only machine and if you like bikes a lot, then it will probably keep a stupid grin plastered on your face all the way down whatever crazy hills you choose to take it on. It is easier to ride than it looks and is quite stable at high speeds (not sure about the speeds you could achieve at a ski hill, but its worked great for average hills in Wisconsin).
There are many ways you could build one of these, this is just one way to get you started.
Build one! You won't be sorry.
Step 1Get a bike
Get a bike
Find yourself a bike that you think would be suitable. I like to keep it small so that its easier to kick with your legs or do a running start and hop on. Smaller is also generally lighter and easier to carry up a hill. In addition, if you crash, you're closer to the ground. I got this BMX that someone was just throwing away. (Seriously, it just had a blown tire and slightly crooked front wheel, wtf?)
Strip all the unneeded parts off the bike. Namely, brakes, wheels and chain.
Look for a removable link in your chain to make your life easier. If there is none, then use a chain tool to push out a rivet. Or just chop it, whatever works.
223 comments
1-40 of 223next »
Feb 25, 2012. 6:16 PMdeweydude says:
This is how you do it
Nov 25, 2011. 7:34 PMbnauss says:
some of the commercial bikes that have longer skis aren't ment for hittin jumps, there ment for runnin downhill and ski hills. the shorter skis are ment for hittin jumps and doin tricks
Nov 21, 2011. 4:00 PMTheLodgeShop says:
really cool DIY project.
Jun 28, 2011. 1:38 PMdfrost says:
can you put it back together
without the brakes cause i have a bike that works but i have no brakes cause i tore them off
Dec 30, 2009. 5:50 PMfortunare says:
thanks for the ideas but Instead of the hokey 2 x 4's I bent some 1/8" Galvanized from Home Depot. Only problem is with two sets of shocks it weighs over 20 pounds plus I;ve just added an extra wide seat that probably weighs 3 pounds.  How do you hook it to the chair when riding up?
Apr 18, 2011. 4:16 PMjsar54540 says:
I bought a commercial ski bike because I found one for a relatively low price and I didnt want it to come apart and crash. To take it up the chair I grab it by the seat boom (or A-Frame, depending on your design) and handlebars and lift it up. Then I set it on the seat and hold on to the handlebars. When you get to the unloading area, shove it off the chair, hop on, and ride away.
Apr 19, 2011. 9:23 PMfortunare says:
thanks, I'm in AZ and only one of our 4 ski resorts allows ski bikes and only during non holiday weekdays so I didn't manage to use it this year. I'm 75 and have bad ankles but seriously considering ankle surgery since even with braces I have trouble walking far, much less skiing. However may still try it. The one I built is very heavy duty and I probably have less than $50 invested in it thanks to finding some super bargain parts. good luck with yours.
Feb 1, 2011. 9:43 PMbenduy says:
could you use pegs from bmx bikes as foot pedals
Apr 3, 2011. 7:28 PMereynoso1 says:
yeah you could, you would have to add them to the axles though
Feb 23, 2011. 9:17 AMPe-ads says:
I guess so. Be creative! That's what Instructables is all about... :D
Aug 25, 2009. 3:42 PMrockymountainrider says:
has anyone done a jump with it? does it get wrecked easy from a fall?
Feb 28, 2011. 8:19 AMsnaketon says:
i guess it depends how strong the bike you use is and how big the jump is
maybe the build quality will come into it at some point
Mar 10, 2010. 3:27 AMtxinote says:
yes!! see my video at down... i do a lot of small jumps the first day...
http://www.youtube.com/watch?v=BJB0zfDvu3k
Feb 28, 2010. 7:14 PMkingbob9_9_ says:
im going to try it as soon as i get a cance to.it probley will if you do a bad job.
Dec 9, 2009. 5:02 PMGlockenator says:
i find the best way to do it is to have 2 skis on the back fork or whatever you want to call it and one on the front fork to steer
Feb 28, 2011. 8:15 AMsnaketon says:
that sounds better.
i should try it when i make one
Feb 5, 2011. 3:08 PMcrazyboy007 says:
me and my friend made one, it was great. thank you for the idea.
the only difference was that we kept the back wheel so we had "propulsion," very fun for icy roads =)
Feb 1, 2011. 2:35 PMkrazy K says:
thats cool:)
wish i could make one
Feb 1, 2011. 6:32 AMwheelerzack says:
Do you think it would make the balance a little better if you put 2 slightly longer skis in the back with the one in the front.
Dec 7, 2009. 10:44 AMshootfilm says:
I'd love to try making one of these, but I live in the South and we get snow maybe once a year; there aren't going to be any old skis in the thrift stores.
Still, this is so awesome I may have to give it a shot anyway.  I'm not crazy about the pedals though.  What if I just put a bar through there to rest my feet on?  Do you think that would work?
Jan 31, 2011. 2:06 PMdirty_valentine says:
If you want fixed pedals just zip tie one of the cranks to the rear stay. That way they will always be up and out of the way. A couple heavy duty zip ties should be able to hold your weight.
Jan 31, 2011. 7:49 AMEh Lie Us! says:
The side 'pedals' foot rest things are a good idea. How does it handle?
Jan 31, 2011. 3:17 AMthomasbleser says:
Some of us are serious about survival and get a little tired of all these narcissistic cheap thrill stuff. For me, it isn't a "snow bike" unless you fit the rear wheel with paddles and both wheels with something to keep you above the surface of the snow when its frozen (like skiis) and above the water (like pontoons) when it's not. We only have so much time to check out indestructables and and most of that time seems to be wasted with most of the bright ideas that come our way
Jan 31, 2011. 7:26 AMdrummonkey92 says:
with all due respect, chill out! you can see from the first picture that this is a fun 'ible that's probably just gonna waste your time
Jan 30, 2011. 8:38 PMmisses_soulful says:
omg this is hilarious. love it.
Jan 30, 2011. 1:05 PMhotcharlie says:
"I want my two dollars!!"
(somebody had to say it)
Jan 30, 2011. 12:09 PMCharlie13 says:
snowscoots are basically the same thing but they are a bit easier to control (getting up on the edges is easier which makes turning easier) This seems a bit more dangerous to the men among us if you were planning on doing any jumps. I can imagine falls being pretty brutal
Jan 30, 2011. 10:37 AMkibukun says:
I WANT MY TWO DOLLARS!
Jan 30, 2011. 10:37 AMactionjksn says:
Who in their right mind would throw a Haro bike frame in the trash. I wish someone in my neighborhood would do that. I don't think I would have used something that nice. I would probably use something cheap like a Huffy.
When I was a kid I strapped a cheap little plastic ski called a Fun Ski, on the front of my Schwinn. I just peddled it on the street. It actually worked pretty well.
Jan 23, 2011. 10:21 AMThatGuyRandy says:
A buddy of mine did this with an old mountain bike, and attached the skis to the
frame with upside down skateboard trucks. This gives you some lean-steer.
Jan 16, 2011. 11:37 PMsoapbox derby car says:
am I crazy or on big jumps would you need a bungee system to keep your skis from pointing in directions poorly suited for landing? I'm just imagining your front ski coming off a jump with some forward rotation and nose-diving when you get to landing.
One example would be if you had a bungee from the front of the front ski to the handlebar tube and a rope from the back of the ski to the frame to keep it from rotating too far forward.
Jan 12, 2011. 2:24 PMMr tech geek says:
As I was reading this I thought "hey I live in Wisconsin too so why not" but ill have to save for the weekend:(
Jan 3, 2011. 2:10 AMharbourlady99 says:
I am intending to make my own ski bike but I am unsure as to what size frame I should go for. Can you advise please
Dec 4, 2010. 12:50 AMunkabuzz says:
Been riding full suspension mountain bikes with X-Bikes/ Hanson / Alpine skibike kits installed on them for 8 years now. Terrain parks, groomed, black diamonds, moguls, trees, powder, etc. Any questions ???
Enjoy the pictures of my many builds.
Unkabuzz
Jan 2, 2011. 8:01 AMlilrou15 says:
That is sick. You should post plans for sale.
Nov 21, 2005. 1:43 PMtrampbiker says:
how did you attach the forks and back end to the skies?
did you machine that out of one solid piece of aluminum or weld three pieces together?
Dec 8, 2010. 12:06 AMunkabuzz says:
As in my original post, these were all assembled from X-Bikes/ Hanson / Alpine skibike kits.
I believe they are "extruded". Pretty tough to do that at home !!!!! I have seen almost an exact replica that was 3 welded pieces ........
Here's another closeup of the "powder" setup. Bungies are critical in the deep stuff though.
Dec 9, 2010. 9:36 AMtrampbiker says:
could you send me the dimetions of the front and back?
Dec 9, 2010. 11:39 AMunkabuzz says:
Please be more specific.
1-40 of 223next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
13
Author:Oblongata
Mechanical engineer - currently designing automated coil winders for a small machine builder.
