Ski Bike
Step 8Finished ski bike!
Finished ski bike!
You're done! Go test ride it if you've got any snow. Make adjustments to the seat and handlebars until it feels right.
To all who may be skeptical of the ski attachment system: I test rode mine the day after I built it on some steep lumpy cross country ski trails and it rode fabulously. The skis did not loosen up or dislodge from their clamped position around a couple fast corners and one fairly good double-up crash. But, if you'd like more security, you can easily cut grooves into the blocks that the axles can rest in and be held more securely.
Afterthoughts:
I might have liked to have cut the skis a little longer, especially after looking at a few commercial ski bikes, all of which seem to run the skis a bit longer and set up so that the tail or the front ski almost touches the tip of the rear.
I did end up raising my blocks from a 3 stack to 4 and I like the change. It handled more predictably and the crankarms didn't hit the ground if you tried to rotate the pedals around, as they did with 3 blocks. My old bike had short kids-length crankarms and it was great, these big ones are a bit awkward.
Things I might change:
I will probably toy with the location of the rear ski, try moving it forward to get a shorter skibase.
It may be a good idea to use threadlocker, lockwashers, or locknuts to hold the axle to the frame, plain nuts and washers have a tendency to come loose, so keep wrenches nearby and check often otherwise.
It's probably a good idea to seal the cut ends of the skis somehow. A layer of silicone or epoxy or something similar should do it, you just want to keep water out so that it doesn't freeze and de-laminate your skis.
I may try replacing the crankset with some form of foot pegs through the bottom bracket. Its what commercial ski bikes are doing and it would probably be easier to kick the bike along or hop on after a running start. The big pedals and cranks just kind of get in the way sometimes.
I would like to make a large padded snowmobile style seat. Allows for more comfortable seated riding, adjustable weight distribution, and will probably look cooler. Many commercial ski bikes do this as well.
I'm considering putting a 26" fork on it to chill out the handling and reduce doubling-up crashes. I'll also undoubtedly monkey with different stems and handlebars.
Other Thoughts:
If you'd like to make one of these to take to a ski area, you might want to make the mounting hardware out of steel or aluminum or something that'll more easily pass safety inspections. Modern kits have torsion springs built into the axles to keep the skis in tip-up position in the air. You'll probably need a leash for the chairlift too.
I'm probably going to make another one of these soon (for experimentation and to have one for friends) using a cheapo full suspension "mountain bike" and longer skis. I'll update on how that works out.
Good luck and happy ski biking!
13 comments
Nov 25, 2011. 7:34 PMbnauss says:
some of the commercial bikes that have longer skis aren't ment for hittin jumps, there ment for runnin downhill and ski hills. the shorter skis are ment for hittin jumps and doin tricks
Dec 30, 2009. 5:50 PMfortunare says:
thanks for the ideas but Instead of the hokey 2 x 4's I bent some 1/8" Galvanized from Home Depot. Only problem is with two sets of shocks it weighs over 20 pounds plus I;ve just added an extra wide seat that probably weighs 3 pounds.  How do you hook it to the chair when riding up?
Apr 18, 2011. 4:16 PMjsar54540 says:
I bought a commercial ski bike because I found one for a relatively low price and I didnt want it to come apart and crash. To take it up the chair I grab it by the seat boom (or A-Frame, depending on your design) and handlebars and lift it up. Then I set it on the seat and hold on to the handlebars. When you get to the unloading area, shove it off the chair, hop on, and ride away.
Apr 19, 2011. 9:23 PMfortunare says:
thanks, I'm in AZ and only one of our 4 ski resorts allows ski bikes and only during non holiday weekdays so I didn't manage to use it this year. I'm 75 and have bad ankles but seriously considering ankle surgery since even with braces I have trouble walking far, much less skiing. However may still try it. The one I built is very heavy duty and I probably have less than $50 invested in it thanks to finding some super bargain parts. good luck with yours.
Feb 1, 2011. 6:32 AMwheelerzack says:
Do you think it would make the balance a little better if you put 2 slightly longer skis in the back with the one in the front.
Dec 7, 2009. 10:44 AMshootfilm says:
I'd love to try making one of these, but I live in the South and we get snow maybe once a year; there aren't going to be any old skis in the thrift stores.
Still, this is so awesome I may have to give it a shot anyway.  I'm not crazy about the pedals though.  What if I just put a bar through there to rest my feet on?  Do you think that would work?
Jan 31, 2011. 2:06 PMdirty_valentine says:
If you want fixed pedals just zip tie one of the cranks to the rear stay. That way they will always be up and out of the way. A couple heavy duty zip ties should be able to hold your weight.
Jan 30, 2011. 10:37 AMactionjksn says:
Who in their right mind would throw a Haro bike frame in the trash. I wish someone in my neighborhood would do that. I don't think I would have used something that nice. I would probably use something cheap like a Huffy.
When I was a kid I strapped a cheap little plastic ski called a Fun Ski, on the front of my Schwinn. I just peddled it on the street. It actually worked pretty well.
Oct 14, 2010. 4:01 PMfunkybassman105 says:
What if you use the fixed pegs like you have, and lower the entire bike? you could attach the tip of the back ski to the bottom bracket.
Jan 21, 2007. 3:16 PMdeweydude says:
I built my first bike similar to the 5yrs ago, It didn;t hold up well. Bunny sled hills that should work for you. But my bikes and riding have evolve from that. to this:[IMG]http://i138.photobucket.com/albums/q256/deweydude/ThePine12-8-06006.jpg[/IMG]
with big mountain back country skibiking. On Mt. Hood OR and multiple resorts for lift access shreddin..
Duane
Nov 30, 2008. 7:07 AMpineapplenewton says:
did you weld those ski attachments yourself? if not what are they and where can i get them?
Nov 30, 2008. 11:03 AMdeweydude says:
Yes, those are home built, I also have Hanson Xbike kits. The mounts are easily made if you have access to a welder, or have a local fab shop build the for you. I'd be glad to give you any help I can. Just ask! check out my buddy Randy at www.skibikefun.com a great source for new and used ski bike equipment. Duane
Nov 30, 2008. 6:51 PMpineapplenewton says:
well since i don't have a welder or axes to a fab shop or enof money to fork out for a bike or conversion kit i came up with my own disine im screwing eye bolts into the ski in the same place where the screws that hold the bindings on went and im putting the axle through the eyes. 2 for each ski.
Jan 28, 2007. 5:48 PMdeweydude says:
send me your e-mail address at deweydude@comcast.net I'll be glad to give you all the help you need and much more detailed pics. Duane
Jun 14, 2008. 2:43 PMI_am_Canadian says:
So I Assume that you just stand on the pedals? Is there any way to make a fixed pole to stand on? I might try this if i can find a bike.... :-)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
13
Author:Oblongata
Mechanical engineer - currently designing automated coil winders for a small machine builder.
